"Tired2way" speaker building.
Old 20th July 2012, 04:02 PM   #571
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Won't do anything, its a matter of structural mass or support against the direct high energy LF wave blows. Such absorption like foam is for the box modes echo control higher in frequency.
Old 20th July 2012, 04:05 PM   #572
Starre is offline Starre  Sweden
OK, but a few ribs that will strengthen the back-panel should make it less prone to make sound itself, even if slight?
Old 20th July 2012, 04:06 PM   #573
Salas's Avatar
Surely any reinforcement there works towards that goal by stiffening. How much of a difference, you can't say if not simulating flex in some special software.
Old 20th July 2012, 04:08 PM   #574
So what do you think is the way to go? I am a little confused. Not much to do, you mean?
Old 20th July 2012, 04:11 PM   #575
Salas's Avatar
I would trust a front to back rod better.
Old 20th July 2012, 04:13 PM   #576
OK, just hard to get in place there. I will see what is possible. I could use one of the bracing side-to-side as support, I guess.
Old 20th July 2012, 04:16 PM   #577
Salas's Avatar
Telescopic something so it can go in easily and you can extend it and tension it after. A bit tensioned and not only connected is surely better.
Old 20th July 2012, 04:22 PM   #578
If i use a rod and support it on the higher of the 2 bracings and angle it upwards it can easiy be squeezed into place with some pressure on it. I have already removed the back stuffing, easy to put back again afterwards.
Old 20th July 2012, 05:18 PM   #579
What do you think of using the magnet of the woofer and connect a rod from it to the back? Takes some fine tuning to get in place, but if I do it might be good?
Old 20th July 2012, 05:44 PM   #580
Salas's Avatar
Its better. Use a pad on the magnet's back. Don't remember if it has a ventilation hole though. If it has, you should not block it.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
