"Tired2way" speaker building. - Page 50 - diyAudio
Old 12th June 2012, 04:24 PM   #491
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You could draw a quick and dirty sketch of your total bracing as it is now, so others possibly interested in making a copy speaker won't have to rediscover America.
Old 12th June 2012, 07:08 PM   #492
Starre is offline Starre  Sweden
Yes, here it is:
Old 12th June 2012, 07:34 PM   #493
Salas's Avatar
Easy, not much to do when building from ground up especially.
Old 12th June 2012, 08:07 PM   #494
Yes, I had to cut the rods in two with a little angle to the cut to be able to get it in place and remove a little damping material to get to the wood of the side panels. The lower bracing was a bit lower in my speakers than your drawing, Salas, so the extra bracing is probably even more effective in my case.
Old 14th June 2012, 12:21 PM   #495
Default Improved stability for stands.
I have investigated an easy way to improve my stands for this speaker.
I found a stone plate that fits and bought 4 of them today. I will use this on the lower part of the stands to make them heavier. My stands are rather stiff but has low weight, so this might help. Reporting later with a picture and how it sounds!
Old 14th June 2012, 01:27 PM   #496
Salas's Avatar
Mikvous had raised to me the importance of stands on this speaker's box coloration in a discussion we had yesterday.
Old 14th June 2012, 02:14 PM   #497
That is interesting Salas, I think the bass performance will improve, but I will report tonight.
Old 14th June 2012, 05:31 PM   #498
Default Everything matters...
Adding some weight to the stands and the bass is very different: faster, tighter and deeper and cleaner. Some of the "fleshy" sound is gone and now more tight and fast. Probably a more "correct" bass. Sounds promising!
I can still hear a few side panel sounds I would like to get rid of, but how to do that is nothing I master at the moment. That might be the last bit of the puzzle to get it right. Anyhow the bass is transformed, hopefully I like it in the long run.
The stone plates are 175x350x5 mm. I added a small front panel making the stones invisible from listening position, not very good looking .
Old 14th June 2012, 05:34 PM   #499
Salas's Avatar
They look like Mission speakers first gen style a bit. Only much better.
Old 14th June 2012, 05:35 PM   #500
Salas's Avatar
Do you couple the box to the stands with something?
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
