"Tired2way" speaker building.
Old 10th January 2012, 02:44 PM   #391
schmutziger is offline schmutziger  Abu Dhabi
salas:
passive cross-over now but not here
minidsp xo in this pic
Maybe i'll start a new thread about my "feelgood" speaker project
note the tweeter is HDS but with a frontplate for my main speakers.
Have original frontplate now.
Old 10th January 2012, 02:49 PM   #392
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Do I see step back top also? Maybe some felt on the ledge to control diffraction. Those drivers are a good choice in combination. I see you like white color too.
Old 10th January 2012, 07:23 PM   #393
Starre is offline Starre  Sweden
I had that idea too, using the tweeter on top of the woofers cabinet but I did not want to alter it since I was not sure what would happen. Looking promising, nice to see it!
Old 10th January 2012, 07:38 PM   #394
Salas's Avatar
It would be an unpredictable outcome. Would need crossover redesign. Cabinet diffraction and centers of wavefront emission are integral to the development of any speaker. At least they should be.
Old 10th January 2012, 07:48 PM   #395
Yeah Salas, I suspected it would mean a different speaker. Maybe if I make a cheap 2-way learning project that idea is worth trying. I was thinking that if you can place tweeter on top but keep the same volume for woofer it would be possible to skip the stands since the tweeter is higher.
Old 10th January 2012, 07:55 PM   #396
Salas's Avatar
The two drivers need keep centers close together. Else, severe lobes are going to form around the transition band.
Old 10th January 2012, 08:00 PM   #397
Yes, but if you make the centers like you said, with the woofer high up in its cabinet, that should be ok, right? Like Smutzigers solution.
Old 10th January 2012, 08:10 PM   #398
Salas's Avatar
Depends in what region this brings the floor reflection destructive interference in combination with listening distance. Center of gravity and mass of construction, impact to box resonance, diffraction pattern due to woofer's emanation point and if it is best point up high, litres you need and if allowing to get enough base area to be stable if building it high, many things. What you will need, is a calibrated mic, handy soundcard, handy software like HOLM Impulse, reading many other projects, time, ideas to test, and passion.
Old 10th January 2012, 08:28 PM   #399
That easy?
Old 10th January 2012, 08:32 PM   #400
Salas's Avatar
No, but its a rewarding hobby.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
