Old 9th January 2012, 08:17 PM   #371
Starre is offline Starre  Sweden
Yes that is nice, Zvuchniak. I am in no hurry with the stands since they work good as is, but of course I will do that later.
I listened some tonight and I could just say this: it is better than my Revel!
I sounds more relaxed and with more potent bass over all, although my Revel has a snappier kind of bass sometimes mabye, but it is not as neutral I think (a little boosted before it rolls of maybe, some like that). The Revel are also harder to place in the room since they need more space to the back wall.
The bass is much better now when everything is in place, it is just right, not that trying to impress boosted bass lift that some speakers got, it just sounds potent without taking over. I am glad I had some discussion with Salas regarding this and stick to that 2.5mH coil, it works very good now with the finished cabinet. Middle range: blends perfectly into the sound, I was afraid my small adjustments/ideas would destroy what I had but it has not, a good balance act. The treble: sometimes you don´t think of it at all which is a good thing I believe, and when it got some "sparkle" in the recordings it comes alive. Also the transition between tweeter and woofer is hard to notice as it should be. I give a big thumbs up for this one, Salas and Miklos (I hope that is the right name ) can be very proud of it!
I should also mention I now use my "real" speaker cables (Nordost Red Dawn rev2), I used the internal cabel type for speaker cable earlier, but I have not compared them directly yet.
Old 9th January 2012, 08:43 PM   #372
Some pictures from tonight:
Old 9th January 2012, 09:35 PM   #373
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Not bad, not bad...
Old 9th January 2012, 09:58 PM   #374
You are the man Salas,
Old 9th January 2012, 10:02 PM   #375
Salas's Avatar
Some day convenient I will photograph and describe a tall black speaker with 4x 6.5inch ported bass cab, with 8 inch dipole hemp 250Hz-10kHz and short ribbon on top octave that I developed for my friend downstairs that plays with an Audio Research VT200. ~91dB/1W. Difficult impedance though.
Old 9th January 2012, 10:20 PM   #376
That will be very fun to see, something tells me it will be worth waiting for .
Old 9th January 2012, 10:31 PM   #377
Salas's Avatar
Difficult for rooms, costly enough, they thrive on big amps, hemp bicone is NOS, its woofers Audax non available anymore. Ribbon is current. Just for box & dipole hybrid ideas to show. Yours which is a practical one turned out very nice. Bravo.
Old 9th January 2012, 10:43 PM   #378
I am glad you liked my efforts, I really wanted them to be as good as possible without taking too much time to realize. I will be happy with these.
If I would start a new speaker project I was thinking a 3-way trying to design myself, but I know that it is very time consuming and I have to study for the knowledge needed so I will leave that until maybe one day I want to try.
Old 9th January 2012, 10:47 PM   #379
Salas's Avatar
If going 3way is better to go big 3way with big amps IMHO. Which means room & costs. If its not for pursuing true scale gains, in small league sometimes two ways can be easier to achieve coherence.
Old 9th January 2012, 10:54 PM   #380
Yes, the wise choice for me should be to build a cheap 2-way of my own to start with, just for the sake of learning. I was thinking some very cheap Vifa tweeter and a suiting woofer.
Going to bed, good night Salas.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS. Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2013 diyAudio
