"Tired2way" speaker building. - Page 35 - diyAudio
Old 4th January 2012, 01:39 PM   #341
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Driving them like screws through pilot holes.
Old 4th January 2012, 02:02 PM   #342
Starre is offline Starre  Sweden
Hi Salas, I did a pilot hole and so on for a tight fit, my concern is that the nut and washer will lose its grip over time and it will only be possible to tighten it if you remove the woofer. Maybe some loctite or even glue is good? How do you diyaudio members do this?
Old 4th January 2012, 02:09 PM   #343
_henry_ is offline _henry_  Australia
sealant can be useful, or epoxy
i usually made my back panels removable.
cheers
henry
Old 4th January 2012, 02:14 PM   #344
Salas's Avatar
Yep, some form of glue aid to hold them better.
Old 4th January 2012, 02:20 PM   #345
most of binding post i know, theres a ring washer to make them tight.
Old 4th January 2012, 02:20 PM   #346
Hi henry, yes removable ones seem practical, I choose single terminals for less cabinet work, but I am not sure it was the case really, lol.
"Loctite" it will be then Salas, it is not fun having to remove the woofer just for tightening a loose nut.
Old 4th January 2012, 02:21 PM   #347
and use the nut to fastened it. what kind of binding post ur using?
Old 4th January 2012, 03:53 PM   #348
This:
Not the best pictures for seeing it but you see something at least. With some loctite I think it will stay in place. The washer is plastic, a metal tag washer could have been better.
Old 4th January 2012, 11:23 PM   #349
speedie is offline speedie  Australia
Default locknuts
starre
put a second nut onto your post holding thread for peace of mind
do this
tighten the primary nut on to your cabinet
snugg it down but dont over tighten it
then fit a second nut to each post and then snugg them down onto the first nut
this is another form of nut and thread locking
the bonus is that if in the future you need to do upgrades or maintenance it is a simple matter of undoing each nut
tring to get loctite to release its bond can be a serious pain in the butt!
please post some snaps of your work so far
speedie
Old 5th January 2012, 06:37 AM   #350
Thanks speedie, but I have already soldered the wires so I can´t fit a second nut.
Yes, the problem with loctite is to get it off if I want to, so if using it maybe you should just use a little to be sure it is possible to remove if wanted.
I will post pictures when the cabinet is ready for drivers, should be in a few days .
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
