"Tired2way" speaker building.
Old 10th December 2011, 11:53 PM   #301
AllenB is offline AllenB  Australia
Many people say they like the midrange contribution from inside their box. If it is helping you then you should consider keeping it. However, another way of looking at it is that any midrange coming back out of the box is not correct. Of course there are worse things, but what to do? If you damp out your box (leaving breathing room for the woofer), you would then need to chase down the reason that your midrange is lacking. It could be a long task and if you want a guarantee that you will like what you find, you're on your own.
Many times I have been chasing something like this. Sometimes I was disappointed that I touched it and lost what I had. Other times I was pleased that I had found the right way to do it.
Old 11th December 2011, 12:14 AM   #302
Starre is offline Starre  Sweden
I made a compromise, I put some plaid (2mm) near the woofer going all the way from side to side. This way I have no surfaces without any damping near the woofer, maybe the difference is too small to notice but I hope it will do no harm at least. The first picture show alternative damping with a little less at the top, not sure what is best. The filter is not fastened yet.
Old 11th December 2011, 05:48 AM   #303
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Since you need the most nice bass possible, you can start with #3, listen, if not content then through woofer hole reach can go #2 but with just one layer at the bottom, since the proto did not have a big crossover down and the damping wasn't coming up that high near the reflex with two layers. For top stuffing #2 & #3 look fine.
Old 11th December 2011, 11:24 AM   #304
Ok, yes it gets a bit crowded at the bottom with 2 layers, the reflex tube is in contact with the damping just fitting above it. Maybe I should go with the alternative with more top stuffing to compensate for only one layer at the bottom which I think I will start with.
Old 12th December 2011, 05:07 PM   #305
I have installed the speaker terminals today, it took some care since the diameter is not the same from the inside and outside. But it worked out well, see pictures. I am sick at the moment so progress is slowed down, but now the only thing problematic is the choice of color, I have a test colored bit picutre taken with a mobile phone, I will try to post later. When ready to paint I will just pop the terminals out a little to get paint under them, and then secure them from the inside. Using this method with the bass reflex tube too.
Old 12th December 2011, 05:13 PM   #306
Salas's Avatar
Got the flu? Wishes to get well soon. As we humored before, the color is gonna be the only issue in the end. That's when the important stuff went smooth.
Old 12th December 2011, 05:23 PM   #307
Yeah I got that darned flu . Thanks for the well whishings Salas .
Old 12th December 2011, 08:03 PM   #308
Ok, here is a sample of the color I have tested. Hope you find it nice, but nothing is decided yet. I think it will contrast nicely with the black drivers.
Old 13th December 2011, 12:45 AM   #309
speedie is offline speedie  Australia
Smile stuffing
hay starre
from your photos of the fill in those boxes it would appear that you are burning the midnight oil
2.30AM on the photo tag would indicate that this project has got you by the short and curlies
hope that you sort out the bass issues that are presenting to you
will be good to see your project completed to your satisfaction
with the newyear coming maybe a new project?
cheers speedie
Old 13th December 2011, 01:18 AM   #310
No worries speedie, i am just dedicated to get this one as good as I can. I think they deserve that, and Salas has been most helpful. I have no plans for a new project yet, but maybe I will. Since I got no response with the color i assume it is not liked, lol.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
