"Tired2way" speaker building.
Old 3rd December 2011, 02:50 PM   #281
bbggg is offline bbggg  United States
Originally Posted by Starre View Post
Yes I will, or some rubber/plastic feet inbetween, I have had that until now.
That's not what Salas said, listen to him, he knows what he's talking about.
High current requirement is the bane of high fidelity
Old 3rd December 2011, 06:11 PM   #282
Starre is offline Starre  Sweden
bbggg: I know Salas knows what he is talking about, so do I, I have been into this hobby for 25 years, at least. I will try what works best .
alspe: I will post a real review when the speakers are finished.
Short version: I have listened to some drums and it sounds very good, clear and natural with good dynamics. I prefer the sound compared to my Revel speakers which are considered a good speaker, that says a lot about the sound quality in my book. Of course I have listened a lot to music with them and not only test tones and such.
Old 8th December 2011, 08:13 AM   #283
Finally got some time to build, the bracing between tweeter and woofer is in place, the port lenght is glued with silicon. Next is the lower bracing, should I have it as close as possible to the woofer for max stability?
Or glue it together with the lower side to side bracing (this makes it placed about 5cm lower than the woofer hole).
Old 8th December 2011, 08:21 AM   #284
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Glue together with the lower side to side bracing.
Old 8th December 2011, 08:37 AM   #285
Ok, will do that,ty. I will try to speed things up a little now to get all ready for painting .
Old 8th December 2011, 08:49 AM   #286
Salas's Avatar
Did you decide the color yet?
Old 8th December 2011, 08:50 AM   #287
_henry_ is offline _henry_  Australia
How about putting cross bracing behind magnets, just enough to touch when u screw the drivers?
Old 8th December 2011, 08:56 AM   #288
Salas: not sure lol, this is still not decided .
henry: I think it will do as it is, but thanks for the suggestion. When I had no back to front bracing (it was like that when I had it assembled earlier and played music) it worked quite well, so I think the bracings I got now will be sufficient, but thanks for the suggestion. I also do not want to change things from Salas original to avoid any surprises.
Old 8th December 2011, 09:01 AM   #289
Salas's Avatar
That's potentially better but takes precise work. Must have a rubber pad and press with enough force to the back plate when woofer's in position. It wasn't available in the prototype since the cabinet was already braced and available from an older real wood speaker. Thus I can not predict the outcome.
Old 8th December 2011, 09:35 AM   #290
U can use some gasket seal tape for ducting. So make it shy 2-3mm, then the gasket will make it tight.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
