Old 17th November 2011, 04:28 PM   #221
Starre is offline Starre  Sweden
Ok, I will report what I hear.
Old 17th November 2011, 04:38 PM   #222
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
How you plan to hear only the bass port without hearing sounds from the woofer? One ear you will cover I suppose, but pen like measurement mics they stick them right in the port's mouth plane.
Old 17th November 2011, 04:55 PM   #223
Yeah I will try to cover one ear, but I am not sure it will work, giving it a try .
Old 17th November 2011, 06:13 PM   #224
Ok now I have tried to listen to the port, and I think it worked rather good after getting used to listen to it. I found some interesting things! First, I have sound from 18Hz which I think is rather remarkable, maybe it is not but to me it was .
Starting at 18Hz it was of course very weak (a 1- on "my" scale) but easy to hear with the ear at the port. Moving upwards to 30Hz, it was quite even and increasing all the way, and suddenly at around 30Hz I heard some sound from the woofer itself, not only the port (it was no sound from the woofers front below 30Hz). Now we are talking 2 on my scale. From 30Hz reaching 39Hz the level is now 3 at 39Hz. Going upwards it increase to 3+ starting at 42Hz to 48Hz. The contribution from the membrane has also increased and is easier to hear than before. 48-57Hz is a little weaker, a 3 on my scale but since the membrane is more active now the total sound is a 4 or even 4+ (around 50Hz).
Ok hope you are still with me on this little trip .
From 57 all the way to 71 the bass port is increasing rather much to its maximum at 71Hz. Over 71Hz it gets weaker with values 3 and 3+ (up and down and so on) to about 100Hz.
What I do not like is the big maximum at 71Hz, it was loud both from the membrane and port . Otherwise it seems fine .
Now the question is, is it possible to get rid of that peak?
Old 17th November 2011, 11:15 PM   #225
Salas's Avatar
Try 71Hz at listening position and move the speakers a little in the front to back axis maybe? Because I see a small suck out at 71Hz in the RTA I took in another room. That's at odds. See if it hits a room node.
Old 18th November 2011, 06:21 AM   #226
Yes I will try that to start with, but I am rather sure it comes from the speaker itself. I will try it to be sure.
Old 18th November 2011, 07:29 PM   #227
I have now tried to move the speakers +-10cm from back wall and it was a rather small change with respect to the 71Hz tube peak (more that it move a few Hz up or down). I also tried to extend the reflex tube to 150mm (from 135mm) but I heard lower output in the 30Hz band which was not better, so I guess going this direction might be a bad idea (I will not try even longer tube since I had this result, and since you Salas set it to 135mm, correct decision?).
I heard from listening position that the 71Hz peak from the tube is not so peaky at the actual listening positions total sound, so that was a comfort. I also heard that with a 150mm port I got a dip at 72Hz from the tube. Comments on all this, Salas?
Old 18th November 2011, 07:39 PM   #228
Salas's Avatar
We had tuned the port in a given room, there it went 135mm. Maybe 130mm & 140mm test in your space for customizing it, if feasible with the telescopic ones you got?
Old 18th November 2011, 07:48 PM   #229
Ok, I think the shortest lenght is about 130mm so I can try that. It is 66mmwide with the telescope part a little wider. My room is 3.8m wide and about 7.3m length. Do you remember the room size you had?
Old 18th November 2011, 07:51 PM   #230
Salas's Avatar
Must be 50m2 including a fully open kitchen annex to its left side, with the main living space maybe 35m2 rectangle.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS. Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2013 diyAudio
