"Tired2way" speaker building.
Old 16th November 2011, 07:19 PM   #201
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Starre View Post
Yes, I dare not to make you disappointed after all help and support .
Just humoring. But we can't beat the communal mind, members can comment very wisely. But you decide.
Originally Posted by Dufus View Post
Starre why not something in the BBC tradition like Harbeth? Eucaliptus maybe?
You see? It kicked off instantly.
Old 16th November 2011, 07:26 PM   #202
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I'm fond of dark reds, black, silver and white myself Darker colors usually seem to blend into the room better when I put a movie on.
Old 16th November 2011, 07:36 PM   #203
Starre is offline Starre  Sweden
Ouch this will make my head spinn lol, but I will read and consider all suggestions. After the baffle is glued in place with braces and the polyester filling glued into place (I am not sure I need to change anything but probably it can be better) I will putty it and sand it smooth. Then a primer layer and then color + maybe some laquer on top. I will also round the braces, maybe it has a little positiv effect. When ready I will post some pictures of the inside to get it right. For example, should the insides be covered with filling all the way to the front, or do you leave a little space to be sure it is not too close to the actual membrane of the woofer?
Old 16th November 2011, 07:43 PM   #204
Dufus is offline Dufus
Dufus's Avatar
It seem ART from Scotland is using the same unit.Price 12500 GBP
Old 16th November 2011, 07:44 PM   #205
Salas's Avatar
As you have it now is ''breathing'' fine.
Old 16th November 2011, 08:07 PM   #206
Yeah Dufus, that is quite some asking price! Have not listened to it and maybe it is worth the money, who knows.
Salas: so it has some influence after all, good to know it seems ok to you as it is. It actually has a little thinker layer in the middle section than you specified I think.
First there is a layer going from bottom all the way up to top. Then in the middle a layer from side to side overlapping the bottom-to-top layer. And a little more than 6 cm as specified in the bottom but at the top above the bracing it is full. Se picture for detail:
Old 16th November 2011, 08:14 PM   #207
Salas's Avatar
Matters a lot especially in a reflex. Should work without hindrance. Else you lose much output.
As for high-end speakers etc. there is no VFM at all in that sector. Its either you appreciate an object of desire and you got no time, but much money, or you just stare IMHO. Only 3rd way to nirvana (3rd way is a Scandinavian TM mindset after all) is DIY.
Old 16th November 2011, 08:18 PM   #208
Yes VFM seem low.
I wonder how that double layer I got in the middle affects sound...
Old 16th November 2011, 08:24 PM   #209
DrDyna's Avatar
Is that stuffing attached? I'd probably hit it with a stapler and fasten it down so it doesn't move around over time.
Old 16th November 2011, 08:28 PM   #210
It is loose but will be fastened with spray glue when I finally glue the baffle.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
