#151 |
I will give you all pictures and put some sealing tape to the front and listen tonight.
#152 |
diyAudio Chief Moderator
Sounds like a good plan. Its productive to make sure its well sealed and best positioned before deciding any coil play.
#153 |
Yes, do not forget I have no experience building speakers so maybe I have overlooked something, and maybe even that coil of mine is not very good. (I will also see if it is possible to glue the baffle soon allowing me to put the filter inside through the woofer hole later, I do think it would be nice to have it inside the speaker which is more practical).
#154 |
Make sure its how you like it first and then you finalize. Take your time. Balancing a speaker in room and dialing in the midbass balance is a leisure act.
#155 |
its great to be guided
![]() cheers henry |
#156 |
Yes, I appriciate all your help! I will take the time needed Salas, I will post pictures as soon as possible.
#157 |
I have done as said, and (!) I hear a clear improvement! It seems the problem was a leaking cabinet. I have just started to listen but I am pretty sure it is ok now. Posting pictures.....
#158 |
And some more...
#159 |
Starre that looks great.What is your set up?Cd/pre/power?
#160 |
Naim cd5x with power supply, music first audio silver pre, simaudio moon w-3 power amp.
| Building a simple "soft start" speaker protection circuit | richard.C. | Power Supplies | 21 | 6th August 2011 08:12 AM |
| "Commercial" install in NP Building Material Store | Destroyer OS. | Everything Else | 2 | 19th July 2010 04:15 AM |
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF | 454Casull | Multi-Way | 0 | 18th November 2008 02:19 AM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
