"Tired2way" speaker building.
Old 31st October 2011, 09:12 PM   #101
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Originally Posted by Starre View Post
Ok I think I have it, I hope the coils are not disturbing eachother!
I should probably turn the left coli 90 degrees and lay the big one down.
See picture..
The others were better IMO (with respect to the coil placement). yes the left coill should be turned 90deg then it should not cause issues. if you have them in their original positions AND turn the left one on its side and at 90 degrees then the chances of interference will be virtually nill however even at fairly close quarters with the coils at 90 degrees to one another (rule of thumb you should not be able to see another coil through the hole of a coil) then they should be ok.
My recent crossover has the coils quite close together. Troel's indicates (in his experiments) that 20cm centre to centre is enough spacing even if mounted in the same orientation.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 31st October 2011, 09:17 PM   #102
Starre is offline Starre  Sweden
Ok, I have not soldered it together since I had a problem with it beeing too tight. You prefer this one (pic)? The only bad thing is I need 2 wires to connect it with. But I can use the same layout and put the components a little closer to eachoter and using you coil orientation advise. And I will lay the big one down west-east to make it more secure to the board.
Old 31st October 2011, 09:51 PM   #103
This should be good. I can use the lead from the capacitors to the right going south to common and only use one wire at the bottom.
Old 1st November 2011, 02:40 AM   #104
just another
wintermute's Avatar
oh I only just realised the tall thin thing is a coil, I thought at first it was an electrolytic cap I think you should be fine with that coil orientation. just for reference, here is a link to Troels test's on coil orientation, at the end it shows the recommended placements. Placement of coils in crossover networks
Tony.
Some of my photos
Old 1st November 2011, 03:00 AM   #105
bbggg is offline bbggg  United States
This should be good
Coil orientation is A-ok here.
High current requirement is the bane of high fidelity
Old 1st November 2011, 10:23 AM   #106
Yeah I will glue it into place and solder it tonight, I spend too much time thinking about this, but ok it is my first time doing it so...
Thanks wintermute, I have looked at it for help.
Old 1st November 2011, 10:41 AM   #107
AllenB is offline AllenB  Australia
Go easy on the glue, you may feel different later on
Old 1st November 2011, 10:50 AM   #108
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I drill the wooden boards and fix with tie wraps in such cases. 2 pairs of holes along a big pp cap axis fix it pretty well. Because something maybe changed to taste later.
Old 1st November 2011, 11:03 AM   #109
Thanks for your concern Salas, I will use a glue that is flexibel and can be removed with a sharp knife. Troels Gravesen uses the same (Placement of coils in crossover networks) on this site. And yes I will go easy with the glue using only so much needed, the big coil needs rather much I guess but otherwise it will be small amounts.
Old 1st November 2011, 11:16 AM   #110
Yes, just as Salas was saying, I was just thinking of adjusting to taste.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
