#11 |
It's interesting because the Onken Calc wants it in a 133L box, I see it as going in about 1/2 that, or 72L net for bass reflex. Greg sees it in an even smaller box, of about 58L.
The 133L tuned to 43Hz looks like an Extended Bass Shelf with a little peak at the bottom. Might play down into the upper 30s. |
#12 |
You apparently didn't take the 2 ohms series resistance [Rg] into account [Qes = 0.438] that will increase the net Vb to a bit > the Onken's. After a quick scanning of the mini-onken article, it turns out I was using Jean Hiraga's 'ultra-bass' [actually mid-bass] alignment which doesn't consider effective motor strength, only Fs, Mms, effective piston radius. That would be dealt with in choosing a tuning point. The mini-onken appears to be only 'mini' referenced to the original Altec due to its smaller driver, differing specs.
Personally, if the specs being simmed are reasonably accurate, I'd follow the well proven design criteria used by WE, Altec and their 'clones', i.e. find the net Vb where Fs is raised 1.56x in a sealed cab, then vent it to Fs or ~99.2 L. No clue why the 'K' factor is 1.57 as I've read nothing to justify it being different, not that it will make an audible difference AFAIK. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#13 |
I think you're right, will double check my sim in Unibox.
EDIT: Checked. I had Rg turned off. The Onken clac volume of 133L looks very good now in Unibox. 99L has just a little bit less extension. Not a bad trade off for a 3rd less volume. |
#14 |
Thanks for the inputs !
It was mentioned that the three Onkens made in Paris have vents lenght |
#15 |
sorry
The server dropped out during posting. It was mentioned that the three Onkens made in Paris have vent lenghts just shorter than the allowed maximum. I tried to achieve the same with supravox 215GMF but it is not possible without redusing the n factor well below 5. as is wentlenght effective between 20/24 cm.To short ? Gm I will look into your suggestion later. As for the specs accuracy ,I do not know maybe an email to supravox will do. Best regards Vegard ps Supravox suggested this: http://www.supravox.fr/kits/jensen215.pdf |
#17 |
according to
Supravox 215GMFHow to tweak this driver to better performance year 2006, the volume of the Jensen box is 102l , 312 cm^2 port areal (300mm lenght) And fs was apparently 65 hz. specs of today says 45 hz Even though the driver has different specs they still recommend the same enclosure ?? What are the consequences of letting vent areal become larger than drivers SD ? Last edited by vega65; 23rd October 2011 at 09:47 PM. |
#18 |
Vega65,
Were you ever successful in getting an English translation of the article? If so I would love to see it. MyFrench abilities don't take me very far. |
#19 |
Is that article from the same Jacques Mahul of Jmlabs/Focal fame?
#20 |
No
(strange maybe ) Guess if I regret choosing german as my second foreign language 30 years ago. I have done some attempts to convert the picture of the article, and run it through google translate.The result is mediocre. (at least when translating to norwegian) So I am typing the french words in a new document, it seems to yield something understandable when running translation to english.It will take a few weeks due to lack of sparetime. I will post it here when ready. |
| Japanese to English translation | Reeler | Solid State | 32 | 24th January 2012 12:17 AM |
| Russian-English Translation of 4P1L datasheet | 316a | Tubes / Valves | 16 | 6th September 2011 12:09 AM |
| Lost in translation...German to English | Bas Horneman | Everything Else | 5 | 30th September 2005 06:26 AM |
| Translation - from dutch to english | Tomv | Multi-Way | 8 | 15th June 2005 07:11 PM |
| german to english translation HELP! | JC Fardo | Everything Else | 8 | 21st March 2005 08:46 PM |
