Old 11th October 2011, 01:22 AM   #1
Default MTM Project Advice
I have some Dynaudio 17W75's laying around and I was thinking of building up an MTM. Any suggestions on what tweeter? I have done a little research and what little I do know is that you need to get the tweeter and woofers as close as possible and the XO point as low as possible. Thanks. Oh and do the woofers have to be angled in? That would make the cabinet assembly more complex.Thanks.
Old 11th October 2011, 02:34 AM   #2
just another
wintermute's Avatar
Is it the original 17W75 or one of the later ones with more extended frequency response? The original looks like it would need to be crossed fairly low (maybe 2K) though you might be able to simply use at notch filter at around 2.5K and cross it there. It is a bit hard to tell the natural rolloff from that graph but it appears to be greater than 24db/octave!
I'm looking at the pdf on David's site http://www.gattiweb.com/images/dynaudio/17w75_data.pdf
some of the morel tweeters may be a good match
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th October 2011, 04:53 AM   #3
AllenB is offline AllenB  Australia
The reason you want to cross low is because the two drivers will behave a little like one driver as big as the two are spaced. I.e. they will become directional and the highs will cancel off axis. Your tweeter won't have this issue so if you cross too high, you will have a power loss in the midrange.
The aim of the MTM is to use the crossover to phase the drivers so you reduce the vertical lobing, i.e. normally there are cancellations between woofer and tweeter just at the crossover region where you either need to suffer a power loss, or allow an on axis peak to make up for it.
You can treat an MTM like a conventional speaker in which case it will appear a little like an offset coax (two-way car speaker), and you'll probably want to phase it carefully around the crossover.
Old 11th October 2011, 12:17 PM   #4
Update: Madisound recommended some tweeters Seas H1499, H1189 DXT tweeter that is used in the IDUNM and a morel with a 94mm flange. Since the Dynaudio is flat out to a few k and then peaks I was thinking of an xo point of 2k or 2.5k
My MTM Project Twisted85 Multi-Way 34 10th March 2008 03:10 PM
Advice on XO MTM WR125S and 27TDFC? Matthew P. Multi-Way 15 7th November 2007 03:55 AM
Need advice on Dayton MTM mike105105 Multi-Way 6 4th September 2007 04:56 AM
need advice re mtm kits/plans wharfrat Multi-Way 2 17th March 2004 04:10 AM
mtm project malcomst. peter Multi-Way 2 21st January 2004 03:30 PM
Page generated in 0.17309 seconds (41.79% PHP - 58.21% MySQL) with 10 queries
