Old 9th October 2011, 06:04 AM   #1
Default ? on building 2 ways
what software u guys using to do designs with and any other help u can give me i have bassbox 6 pro and xover 3 but cant figure out how to use it for two differnt drivers
Old 9th October 2011, 05:06 PM   #2
I use the same software.
Not sure what you mean by two different drivers. W & T or, are you comparing two different woofers?
Old 9th October 2011, 07:17 PM   #3
yeah woofer and tweeter i have used that program for many years but it was just used for building sub boxes in car audio but have gotin older and in to home audio stuff and it has been awhile since i have used this program and dont have the paper manual anymore
so any help would be great
Old 9th October 2011, 07:44 PM   #4
For the bassbox portion, the tweeter has no effect on the design of the box, so it isn't needed. Just plug in the woofer T/S parameters and go from there.
However, for the crossover design, then you'll have to enter T/S paramaters for both drivers. That portion of the software does provide for both drivers.
this is not terribly sophisticated software. for example it doesn't have provision for baffle geometry or C to C distance between the drivers.
PCD is much better for this, but to use it effectively, you'll need full impedance and response data sets.
Old 10th October 2011, 03:11 AM   #5
ok thank u thats what i thought it has been 15 years since i have worked in the car audio bis and i have to get back in the swing of audio again but thank u for the info
Old 10th October 2011, 01:24 PM   #6
Hi, see links below, but best off starting with a good existing design, rgds, sreten.
Describe the sort of thing you want, there will be something out there.
http://sites.google.com/site/undefinition/diy (see FAQs)
Zaph|Audio
FRD Consortium tools guide
http://web.archive.org/web/200909021...esigningXO.htm
RJB Audio Projects
http://web.archive.org/web/200909022...ve99/Spkrbldg/
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
DIY Loudspeaker Projects Troels Gravesen
Humble Homemade Hifi
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
Great free SPICE Emulator : SPICE-Based Analog Simulation Program - TINA-TI - TI Tool Folder
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Building 2 ways Ellam-XT Crossover sleep888 Multi-Way 2 22nd April 2009 01:32 AM
Hi-vi 2 ways lodger_001 Multi-Way 5 12th February 2007 12:38 AM
The New 2-ways. Spasticteapot Multi-Way 16 19th November 2006 12:39 AM
2 vs 2.5 vs 3 vs 3.5 vs 4 ways Sony Multi-Way 4 7th December 2004 03:27 PM
2-ways + sub OR 3-ways EyalR Multi-Way 12 18th January 2004 04:48 PM
Page generated in 0.08278 seconds (78.58% PHP - 21.42% MySQL) with 10 queries
