Old 9th October 2011, 06:00 AM   #1
vdB is offline vdB  Netherlands
Default Direct 'Measurement' of AU-Based Digital XO
Hi all,
(First post here! )
Lately I've been playing around with CrossoverUnit, a set of Audio Units implementing some well known crossover types like Butterworth, Linkwitz-Riley etc. in the digital domain.
To get a better understanding of what I'm doing I'd like to inspect the transfer functions of the various configurations I make in AU Lab. Basically, what I'd like to do is described here, but I was wondering if there is free software around that can do the same trick.
I've tried REW, but it doesn't seem to be able to take specific Soundflower channels as input. I'm not sure if there is a workaround for this?
I've also looked into Audacity, which can generate sweeps and analyse audio data, but for this I need to capture AU Lab's output somehow. Perhaps this could be done with AU Lab's 'record' button, but I'm not sure if this is the best way to do things.
Any ideas?
Old 13th October 2011, 07:25 PM   #2
boris81 is offline boris81  United States
Look up a free software called HOLMImpulse. I've used it to do what you need but with a different filter platform.
REW should work fine too.
You need to plug a cable to loopback from your soundcard's output to the input.
Old 14th October 2011, 05:18 AM   #3
Thanks boris81. It looks like a great tool. However not for the Mac?
Thanks for the loopback tip too. Unfortunately my 13" MPB has only one audio jack socket. Otherwise REW would probably have been fine indeed.
PC based digital crossover with dolby digital live preiter PC Based 64 25th April 2012 08:14 PM
The CYP AU-D3 Digital to Analogue Converter whats gan on Digital Line Level 2 29th August 2011 08:29 AM
Sansui AU-alpha607MRX measurement panson_hk Solid State 0 29th June 2010 07:17 AM
Digital XO vs Op-amp XO, which would be best to use in active speakers? MikeHunt79 Analog Line Level 11 16th November 2009 05:06 PM
Cu or Au foil based spkr leads peted Multi-Way 8 1st October 2004 06:57 PM
Page generated in 0.07904 seconds (69.26% PHP - 30.74% MySQL) with 10 queries
