Old 9th October 2011, 01:30 AM   #1
dbsun is offline dbsun  Australia
Default which mids and tweeters for 2-way?
I'm trying to decide on some mids and tweeters for a new 2-way project.
I like the Vifa XT25TG30-04 tweeter because it measures well, goes to 40khz, there are plenty of designs around using it and the price is good ($36 each locally) but the poor off-axis response worries me - is it a problem in real-world designs? Is there a better sounding tweeter for similar or slightly more money eg. Peerless 810921 or Seas T25 CF002-06?
For the midbass driver I'm torn between the Scanspeak 15W8530-K00 and the Peerless 850488 (still available in some places). Linkwitz seems to prefer the Peerless as it measures better and is about half the price of the SS but he doesn't really comment on the sound. I know this is a subjective area but does the Peerless sound every bit as good as the SS? Or perhaps I should be asking: what are the subjective sound characteristics of each driver? Also is there a better sounding midbass driver? Thanks.
Old 9th October 2011, 06:12 AM   #2
Do you need to do your own thing or are you OK with an existing project?
Old 9th October 2011, 06:46 AM   #3
gornir is offline gornir  Sweden
gornir's Avatar
Hi dbsun,
Both the Peerless 810921 and the Scanspeak 15W8530-K00 are great drivers, but I would choose the newer ScanSpeak D2608/913000 version of the HDS driver and the 4 Ohm and uncoated version 15W/4531G00. In my opinion the uncoated version of the 15W sounds better and is a perfect match to the HDS driver and as a bonus you get about 3db higher sensitivity.
The 15W/4531G00 midrange sound is one of the best I’ve heard. It’s detailed and spacious, but without sounding analytical. The HDS tweeter is fluid an effortless with a nice sparkle and glimmer at the top without sounding exaggerated or fatiguing.
Look at this build to get some inspiration SR551-HDS -- 2-way standmount
/Goran
Old 9th October 2011, 07:17 AM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The 850488 is a great driver (I use it in my HT speakers) but can't compete with the 15W8530. The SS Revelators are special and the 18W is used in my mains.
I'll second the 810921 or the SS version as it's a great tweeter and use it in my two best designs.
If you are looking at the 850488, have a look here for an easy design.
Peerless HDS 134 +
For a 15W speaker look here for a design.
Ellam-XT
While you are there, have a look at Troel's other designs as will give you some ideas.
Old 9th October 2011, 08:13 AM   #5
Moondog55's Avatar
Just in case you didn't know "Speakerbits" still has stock of the P13 if yo wanted to build any of the iterations of the "Reference" 2-way.
Vifa bass/midranges, Peerless bass/midranges, Scan-Speak bass/midranges, Quadral bass/midranges - Speakerbits
diyAudio reference speaker project
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Last edited by Moondog55; 9th October 2011 at 08:18 AM. Reason: I made a spelling mistakle
Old 9th October 2011, 10:56 AM   #6
ODougbo is offline ODougbo  United States
I have that tweeter, its awesome, a very good value, I’m sure the price will skyrocket.
So check out this Madisound kit using the tweeter, a great deal.
The fellows at Madisound are really into crossovers, the midrange is exceptional, it would be hard to beat what they have come up with. The xover does come assembled.
I’ve built 10 of these so far, sold/gave all but 1. My friends are thanking me every time I see them. I’m using the last one as a center; going to build more this winter.
http://www.madisoundspeakerstore.com/mtm-speaker-kits/hds-home-theater-kit-parts-only/
BTW, the mini woofers do need time to break in, but they will, mine are really cooking now!!
Old 9th October 2011, 05:12 PM   #7
Here is a great build with great technical homework already having been done. The tweeter has a waveguide faceplate that yields great off-axis response. The parts w/cabinets run about $600 US.
If you want to go even more high end, substitute the Seas woofer/mid with a SS 15W 8530K-01 with just a series wired 3.0 mH coil. You won't need the parallel trap circuits if you use the SS.
The Seas ER18DXT ported two way
Old 10th October 2011, 07:40 AM   #8
either way is fine, Casull. Just interested in the better drivers as a starting point.
Originally Posted by gornir View Post
Hi dbsun,
/Goran
Thanks for your views Goran. Interesting project on your link.
Peerless HDS 134 +
Ellam-XT
yes I've seen those designs by Troels. Interesting that you rate the SS midbass over the Peerless. Any significant differences between the SS and Peerless versions of the 810921?
yes I've noticed they still have stocks but would you rate the Vifa P13 over the Peerless or SS? It doesn't seem to measure as well as the other two.
Do you find the off axis response of the Vifa noticeable or a problem in any sense?
Thanks Speakerdoctor. How do you think the Seas drivers compare to the Peerless and SS? I will have to have a look at their response graphs.
Old 10th October 2011, 08:21 AM   #9
"For the midbass driver I'm torn between the Scanspeak 15W8530-K00 and the Peerless 850488 (still available in some places)."
Peerless 850488.....I think that may have been the replacement for the 1591. I bought boxes of those. I couldn’t believe they stopped making that driver, it has some bass. (pic 1 of 20 year old 5 ¼ peerless, I don’t think it will ever quit).
I think you’ll like the HDS, and at $132.5 they priced it well. I found another pic (2) of “what you get” with Madisound’s HDS.
Old 10th October 2011, 08:53 AM   #10
Thanks, for the peerless design, I would have built a pair in a jiff if I known. I don't know about finding the mid driver now though :-/
We used a first order design for the 1591 triangles boxes (aggressive angled boxes). Went overkill on the box, 1” MDF, loads of glue, clamps, they are also lined with lead “cannonball speakers”.
I have the original prototype pair in my shop, still going since mid 1980s. I do on occasion damp the surrounds with ArmorAll.
Peerless HDS 134 +
Ellam-XT
Goto Tweeters/mids tomtt Multi-Way 15 16th January 2012 07:34 AM
WTB AR3a tweeters and mids. SatinMill Swap Meet 8 31st August 2011 10:16 AM
NOS DQ10 dome mids and tweeters baddjonny Swap Meet 3 26th March 2011 08:48 PM
x-over levels for mids and tweeters Pete H Multi-Way 5 30th June 2005 07:39 PM
revelator tweeters and mids for sale shaynet Swap Meet 0 3rd February 2005 11:19 AM
Page generated in 0.15468 seconds (87.29% PHP - 12.71% MySQL) with 11 queries
