in-room frequency response & transient response
Old 8th October 2011, 01:12 AM   #1
MCPete is offline MCPete  United States
Default in-room frequency response & transient response
(in his paper on the acoustic suspension method) Villchur says that uniformity of frequency response is an index of transient response.
So consider first of all a theoretical speaker system that has flat anechoic frequency response. Then put that speaker system in a room and the measured frequency response at a some point away from the speaker including reflections from the room is no longer flat. Does this mean that the transient response of the reproduction by the speaker system in the room has been degraded?
Further, if active equalization is used to make the frequency response of the speaker system in-room flat, does this mean that transient response of the reproduction has been restored to optimum.
Also I was wondering if the change of transient response with frequency response is significant, that is, if it would be very noticeable in listening to music.
These are just my theoretical musings that I'm curious about. -Hope that others find this interesting.
-Pete
Old 8th October 2011, 06:31 AM   #2
AllenB is offline AllenB  Australia
It's hard to ignore the time delay of the reflections, this is a component of diffractions as well. EQing can have only limited influence and I think there is some good inormation on the perception of time delayed versions of a signal at various time delays to be found on this site.
in-room frequency response & transient responseHide this!Advertise here!
Losing the treble and transient response in this PX25 SE amp rtsang Tubes / Valves 19 23rd June 2013 10:01 AM
low frequency room response - front vs. rear ported JLC7 Multi-Way 0 3rd May 2009 02:04 AM
Controlling transient response AdamZuf Tubes / Valves 29 6th July 2007 01:38 AM
Room mode, so bad bass frequency response (with or without dipole) ;( mbon Multi-Way 2 21st June 2004 05:53 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
Copyright ©1999-2017 diyAudio
