3 way sealed loudspeaker design
Ok, could someone help me model a 3 way speaker in WinISD? I'm a little confused.
Do you have to model each driver separately in the same size enclosure, or is there a way to put 3 different drivers into the same enclosure to produce a single curve?
Also, how do you model a 3 way passive filter?
