Old 7th October 2011, 05:11 AM   #1
alspe is offline alspe  Finland
Default Sound of ribbon tweeters
Have you heard that ribbon tweeter had somekind of sound of their own, I mean in a good way? Do they have sweeter top and better transients that I have red in internet? Only ribbon is Elac's air motion transfer / ribbon in 310.2 JET I have heard and it was very nice.
Ribbons usually do not like crossed low because of distortion. That is strange because they have more area than small dome and still distort more. Would you use ribbon IF you'd cross around 5000 Hz?
Have you used ribbons as super tweeter together with dome tweeter, simply driven with 1st order capacitor XO above 10 kHz for example? Does it give nice glitter or what?
Old 7th October 2011, 10:40 AM   #2
Loren42 is offline Loren42  United States
I use the Beyma TPL-150 and cross it at 1.2 kHz. Seems to work okay, but I am probably pushing the limit at this frequency.
Yes, they do sound good and much better that the Morel MDT-37 dome tweeters I was using. They also have superior dispersion characteristics.
Old 7th October 2011, 04:06 PM   #3
gornir is offline gornir  Sweden
gornir's Avatar
I would say that when they are used properly they sound absolutely fantastic. However it’s up to personal taste and the dome vs. ribbons discussions tends to divide people into two camps. I like both, but of course in different types of designs.
I think sometimes you shouldn’t always analyze every technical detail aspect of dome vs. ribbons and their differences. Sit down and listen… Do you enjoy the sound when listening to music? Go for it……
The higher quality ribbons play almost as low when used properly as the best domes without distortion concerns becomes an issue. However in my opinion the midrange driver choice becomes a bit more critical in order to integrate with a ribbon nicely. Domes are a bit more forgiving in that aspect.
/Goran
Old 7th October 2011, 06:20 PM   #4
mondogenerator's Avatar
Default any advice xo point ~3k?
Ive seen the Visaton MHT 12 magnetostat tweeter, and considered it a possible upgrade to the g20sc im using with the al130 woofer, but I have also seen the Mivoc KFT130m ribbon and it is considerably cheaper!The general aim would be to replace the current tweeter, and HP filter, but hopefully keep the LP to the woofer relatively unchanged.Ive also looked at some of the Fountek ribbons, but some of these are similar in price to the Visaton MHT12.Has anyone used this Mivoc ribbon before?Its almost surprisingly cheap.
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone.
Old 7th October 2011, 07:38 PM   #5
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
I have a Swans RT1 ribbon it did not outperform the visaton dsm25ffl titanium dome I compared with.
I did have better performance from morel dome and horn-loaded drivers. I listen to a 2" now it seems the guitar sound sparkles in the air. Like all other horn lovers the dynamics are addictive.
So as for the ribbon I thought it would be ahead of other techniques but mine RT1 didn't show off as better.
Ribbons have a porer dispersion as a normal dome. Is often not in specs.
Mundorf specs them.
http://www.mundorf.com/english/speak...ransformer.pdf
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 7th October 2011, 08:09 PM   #6
slightly less horizontal dispersion and more controlled vertical dispersion is the reason i am interested in those drivers. The aim to improve the power response in comparison with a dome. I have tangband 2" and 3" and alpair5 i COULD use...
Old 7th October 2011, 08:10 PM   #7
Helmuth's Avatar
It will result in a smaller sweet-spot.
Old 7th October 2011, 08:27 PM   #8
yes i expect so
much like a cone tweeter may have a smaller sweet spot, though less so in the vertical dimension.
Old 7th October 2011, 08:35 PM   #9
Helmuth's Avatar
yes i expect so
You want a cheap ribbon.
RBT-95SQ Bändchen-Hochtöner MONACOR
Old 8th October 2011, 02:16 AM   #10
...... and horn-loaded drivers. I listen to a 2" now it seems the guitar sound sparkles in the air. Like all other horn lovers the dynamics are addictive.
and fast attack, rendering instruments like guitar very realistic. I find good horns exhibit a much deeper sound stage too.
AmpsLab.com
Stacking ribbon tweeters? RobertR487 Planars & Exotics 12 9th October 2009 03:38 AM
Ribbon tweeters barackuda Multi-Way 35 14th July 2007 11:24 AM
Ribbon tweeters in Car? vision Car Audio 4 26th October 2006 11:30 PM
Need help: ...... Ribbon tweeters !!! Mrpong Multi-Way 7 9th July 2005 03:52 PM
ribbon vs dome tweeters MyNameIsJake Multi-Way 15 21st April 2005 09:17 AM
Page generated in 0.11717 seconds (81.10% PHP - 18.90% MySQL) with 10 queries
