Old 6th October 2011, 07:04 PM   #1
Moondog55's Avatar
Default Daydreaming again
Replacement Woofer for 15" Realistic Mach One 4 Ohm 290-182
I saw that these are on sale.
I was just wondering to myself why??
For some reason the sound of a high "Q" driver in a large closed box just 'sounds' right.
Perhaps that is because my musical tastes are firmly rooted in 60s and 70s Rock & Roll and I grew up to the thunder of Pink Floyd and Mike Oldfields "Tubular Bells"
The Realistic Mach one were not the best speaker I ever heard when I was a kid but they did have the best bass, so what was I hearing? A big mid-bass peak or did they truly rumble and thunder as I remember??
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 6th October 2011, 07:37 PM   #2
dirkwright's Avatar
Well, Fs is 20Hz.... so maybe there's hope...
Old 6th October 2011, 07:39 PM   #3
David Gatti's Avatar
15" woofer in a big box has the effortlessness, the way nature intended it, like a big V8.
Old 7th October 2011, 12:10 AM   #4
Looks pretty nice in 15 ft^3 sealed and very nice in 30 ft^3 (give or take) ported. A little bit larger than the original enclosure. Assuming the original enclosure was about 4 ft^3 sealed then it still looks reasonable down to a bit below 40Hz but would be down about 6dB lower at 20Hz than the optimum size.
mike - www.keepingsundayspecial.org
Old 7th October 2011, 12:21 AM   #5
Moondog55's Avatar
Much larger than the original enclosure size;LOL; which was ( I'm guessing here ) about the 4cubic feet but fully stuffed.
But why did I think they sounded so good??
I haven't seen a waterfall of the replacement drivers so no idea of the XO needed or at what point they should change to the mid but the old ballpark of 300 -- 3000 springs to mind
Old 7th October 2011, 01:03 AM   #6
gainphile's Avatar
Fs of 20hz and critically-damped Qts of 0.5 is perfect for dipoles !!
That would give you -6db at 20hz.
http://gainphile.blogspot.com
Old 7th October 2011, 01:18 AM   #7
AllenB is offline AllenB  Australia
This might help with the crossover frequencies.
Realistic Mach One SpeakersAmerican Bosch 670T Radio
Old 7th October 2011, 01:22 AM   #8
Moondog55's Avatar
800 and 8k
Wow is all I can say,
Old 7th October 2011, 01:30 AM   #9
800 is a good place to cross from a dispersion matching point of view. Finding the right 15" to do it would have been the issue. I guess this explains the ribs on the cone, and if I didn't misread something they may have been made by fostex?
Not that I wouldn't question their ideas on dispersion. Their horizontal line arrays in the later models are interesting to say the least from a domestic point of view.
Old 7th October 2011, 01:47 AM   #10
Moondog55's Avatar
Fostex may be right, shame I can't afford any of these
Page generated in 0.10242 seconds (77.69% PHP - 22.31% MySQL) with 9 queries
