hey guys, i got a pair of dali hybrid tweeter from the internet lately but suddenly found a problem on how to do a crossover for the ribbon
shall i do the same type of x-over like i did for domes? many thanks for reading the pic of the tweeters as follow:
#2 |
you may find this interesting:
Dali 800 renovation |
#3 |
The crossover design will depend largely on where you select the crossover point to be. The dali example at the link has a 1 uF cap in series which indicates a very high xover point - perhaps in the range of 10 khz or so to add air to the soundstage
Low crossover points in the 1K to 5 kHz range will require higher order slopes to protect the delicate ribbon element. 4th order slopes for ~2 kHz xover in two way designs are not uncommon. |
#4 |
a small series cap is all you need
and most likely also a series resistor just change values until it sounds right my best bet is that it will sounds best when you barely hear any sound from ribbon its best job is to control phase |
#5 |
Speakerholic
I've found that ribbons seem to like 5K and up. Below that, I've not found one that sounds "natural" - whatever that means.
#6 |
got it, thank ya all pals
i saw the impedence curves for both dome and ribbon, the resonances are about 1300Hz and 5k. |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| ribbon planar tweeter with low crossover frequency | LineArray | Planars & Exotics | 2 | 19th June 2008 09:13 PM |
| Tweeter Box Crossover with Ribbon and Bullet Dome Tweeters | doccbst | Planars & Exotics | 2 | 5th August 2005 04:54 PM |
| Using a ribbon tweeter with an active crossover | sardonx | Planars & Exotics | 19 | 18th June 2005 04:21 PM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.08563 seconds (75.10% PHP - 24.90% MySQL) with 10 queries |
