Finally I have completed the project with an good stand
the Monitor 3 This is a model 2 clone of Foundation What you think to try Glisdome instead of spike ? http://www.audiodesignguide.com/HiEff/Glisdome.jpg http://www.audiodesignguide.com/HiEff/base.jpg |
#2 |
Does it help with a stand to maximize the floor bounce effect?
![]() Isn't this a smarter stand near the floor?
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 1st October 2011 at 06:39 PM. |
#3 |
I suspect every one who likes small loudspeakers on a stand do not like to hear sub-bas below 40Hz.
The floor bounce and the reflection on the rear wall will delete all sub-bas, and the satisfied user will say very good clean bass because of the missing sub-bas. Although he bought a speaker that goes down to lets say 40Hz. Then he will think how good bass sounds with the sound of his little monitor in mind he will compare other speakers. I think a stand box with woofer near the floor and mid en tweeter on listener height is better to have also bas. Or in this case put the monitor on a little stand 20cm of the ground with a little 5 degree angle it will also extend the sub-bass level.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#4 |
I suspect that people who like boxes on the floor do not like to hear stereo with a realistic image height.
Unless they like a balcony perspective... |
#5 |
I such a case I think the monitor even lacks good sound stage or you forgot to place it at a angle.
#6 |
Those tweeters are an eyesore.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#7 |
Helmuth,
where you have read about this mic position ? |
#8 |
It is clear that the microphone position is to show the effect of different path length caused by floor bounce, one at listening hight with combfilter one at the floor without the combfilter. As shown it causes extra comb-filter effect.
The Floor-Bounce Effect – Mic Placement for Equalization Synergetic Audio Concepts
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 2nd October 2011 at 10:38 AM. |
#9 |
im interested in floor bounce, since in almost every case, a degree will exist. The variables would be distance/frequency of fundamental combing nulls.
Would wall stand mounting help or worsen the situation? Im thinking of designing my next monitor to be wall mounted on a cantilever, with pivot, in each corner.
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. |
#10 | |
With my dipole low I came to the conclusion that a monopole 1,5 mtr away from the rear wall will kill it own radiation of 1,5 (1/4 lambda) X4= 6mtr 1 lambda. 344/6mtr=<60Hz so frequencies under 60 Hz will decrease by the reflection of the rear wall. As compared to the dipole this reflection stretches the sub bass and helps to increase the subbas level.
| Budget V's High End??????? | nad | The Lounge | 2 | 28th November 2009 09:09 PM |
| Compact budget subwoofer: vented or TL/Horn? | mvangel | Subwoofers | 21 | 5th February 2009 11:21 AM |
| A perfectly nice budget high-end hi-fi... | mjarve | Everything Else | 4 | 16th August 2004 03:21 PM |
| Page generated in 0.10797 seconds (80.09% PHP - 19.91% MySQL) with 10 queries |
