#41 | |
Your welcome! Actually I don't really look at his comments or his ratings. Looking at the 8" driver roundup *data* both the Visaton and the Usher are lower in distortion (below 100 Hz). Of course both have lower excursion and a higher fs. I couldn't tell you about the lower freq. distortion performance of the Lambda 10, could be better, could be worse. I would say however that you have more excursion with higher compliance, and greater sd - which should result in better performance. As for cabinet size, the 3.5 cubic feet is a recommendation but not an absolute by any means.. basically it's all down to how low in freq. you want to go vs. power and maximum spl.
perspective is everything |
#42 |
Maybe you could take a look at the Newform ribbons. They sound terrific and with their length and ablity to be adjusted up and down on the mounting pole make them very versatile. The 1000hz + crossover point allows you more options with your other drivers also...
LINESOURCE REFERENCE - Ribbon Array Ultra High End Audio Speakers for Home Theater and HiFi Music Systems |
#43 |
BG have also line array's that play the hole midrange usable as dipole or monopole. They will do a lot of things better then a cone driven speaker I guess, and they will also have their drawbacks I don't know because I never used them.
RD40 300-20000 RD48 250-20000 ![]() Stig Eric likes them a lot I read of his reply's.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 1st October 2011 at 05:36 PM. |
#44 | |
I’m extremely found of the ScanSpeak midrange sound so I think I stick with it. The question for me right now is which woofer and tweeter to combine with the midrange. The smaller ribbon R8 could be interesting, but it's quite expensive and has a low sensitivity. Regards /Goran |
#45 | |
All the Alternatives would make great speakers, but I like "Alternative #1", because the crossover frequencies are outside the critical "telephone" passband. Have not heard the 15M, but I've heard the 15W and it is about the best mid/woof you can buy. Along with the RAAL you are at the end of the road. If you can give a listen to some Wilson Audio or Dunlavy speakers. You may not like them overall, but they do some things really well, especially the larger ones. I might add, if it is possible, you might try to have a separate upper bass driver dedicated to around 75Hz to 250Hz. Some may even argue that this is actually where most of the visceral energy or life of the music is. Unfortunately, this is really expensive (almost prohibitive) to do passively, but there is an effortless impact to the sound that conventional 3-ways lack. Of course, a properly designed 3-way might be all that you will ever need and is miles ahead of any 2-way. |
#46 | |
Thank you for your kind words ![]() I have decided to scrap my alternative 2 and 3. I will stick to my alternative 1 with the 8” Scans. However, this design sketching has grown to 3 different 8” configurations with 3 different tweeter and 2 midrange options. I was a bit curious on the Illuminator series, but I couldn’t find enough information about them to make it worthwhile to proceed on that track. Soon I will post my new design thoughts and some box sims around the SS 8”. Regards /Goran |
#47 | |
Sorry - posted out of sequence. |
#48 |
You might consider Skaaning. Speakers are not designed by corporations, but by skilled engineers, and I consider Skaaning to be one of the most talented engineers in the field - he's the one that designed some of the best-known Scan-Speak drivers.
True, they're not cheap, but that's not surprising when you consider these are not Chinese-made drivers that mimic the look of Scandinavian drivers, but the real thing, made in Europe. I've heard speakers designed around the Skaaning drivers, and I weren't so deeply into the high-efficiency thing, those are the ones I'd choose. RAAL makes superb ribbons, but keep in mind that even the large ribbon is at its best well above 2 kHz - 3 to 4 kHz is a better choice for the crossover point. So if your heart is set on ribbon treble, do yourself a favor and select a midrange that needs as little equalization as possible through 5 kHz, or above. I would avoid any mid that has resonances in the 3~5 kHz range - sure, these can be equalized, but after equalization, there are still noticeable colorations, particularly in comparison to a ribbon tweeter. When drivers break up, strange things happen to dispersion (thanks to multiple emission surfaces on the cone that go out of phase with each other), and equalization cannot correct for dispersion anomalies. It's easy to be hypnotized by the power of digital equalization, but it doesn't magically make drivers flat, despite the measurements (at one point in space). Move the microphone around, or check the distortion spectra, and you'll find the resonances are still causing trouble - it's just been shuffled around to another domain that isn't as easy to measure. Try and choose a midrange that is a good complement to the RAAL - flat response, with very fast decay characteristics, and not requiring a notch filter in the passband or above the passband. Very few mids meet that criteria. As you may have noticed, many commercial high-end systems with ribbon tweeters have poor subjective integration between the ribbon driver and bass/mid driver. Following these guidelines will save you a lot of expensive mistakes. Last edited by Lynn Olson; 2nd October 2011 at 10:24 PM. |
#49 | |
#50 | |||||
Hi Lynn,
Thank you for your insightful comments. Quote:
![]() Yes, unfortunately they are a bit more expensive than the Scans. Quote:
Picture 1: No smoothing , Tweeter-axis, Blue=0deg, Red=15deg, Green=30deg. Picture 2: No smoothing , Tweeter-axis, Blue=0deg, Red=30deg, Green=45deg. Quote:
![]() Regards /Goran Last edited by gornir; 3rd October 2011 at 06:45 AM. |
| DIY - Super High End Kits | VACS | Multi-Way | 142 | 30th December 2012 03:21 PM |
| High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 09:43 AM |
| floor stander speaker system | zackkstar | Multi-Way | 1 | 12th June 2006 03:13 PM |
| high end version of low end phono stage | dsavitsk | Solid State | 20 | 1st September 2005 11:51 PM |
| How high should woofer be off floor? | toenail | Multi-Way | 2 | 30th March 2003 09:31 PM |
