Super High-End 3-way floor-stander - Page 13 - diyAudio
Old 19th October 2011, 08:27 PM   #121
gornir is offline gornir  Sweden
gornir's Avatar
Originally Posted by PandazYa View Post
Any news about your project?
I had a similar project as yours in mind and being a huge fan of scanspeak I had to admit to myself the 15h52 was the "one" for my 3-way
I ended with this setup:
Raal 70-10 (If only I could get the 70-20XR!!!)
AT 15H52-06-13-SDKAM
ScanSpeak 8861T00
Expected cross freq: 300~400 / 3500~4000
Im working on it atm I'll let you know how these beauties sound together!
Hi PandazYa,
Yes, the work is progressing and Iím about 90% sure which drivers I will use. I have done some box simulations which look promising, but I havenít had time write anything down yet.
Your setup looks great. I hope you write it down and share it with us
/Goran
Old 25th September 2016, 10:48 AM   #122
to earlier mentioned planned use of Scan Speak 10F as midrange from abt 300Hz.
Having used SS 10F as a midrange in various configurations, dipole and normal can say it really struggles with crossover point less than 700-800Hz on normal sized baffles and less than 400-500Hz on wide (35cm+) ones. On other hand it does quite well up to 7-8kHz on top end. Can even run tweeter-less although the sound becomes a bit "retro".
There is 3 versions of this driver - large manget 4/8ohm which has better sensitivity and low end, and also small magnet version which is noticably cleaner over 1.5kHz all the way into 10-12kHz but its only 85dB/1W with limited power handling.
DIY - Super High End Kits VACS Multi-Way 149 6th July 2015 11:54 AM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 10:43 AM
floor stander speaker system zackkstar Multi-Way 1 12th June 2006 04:13 PM
high end version of low end phono stage dsavitsk Solid State 20 2nd September 2005 12:51 AM
How high should woofer be off floor? toenail Multi-Way 2 30th March 2003 10:31 PM
Copyright ©1999-2017 diyAudio
