Old 5th October 2011, 08:56 PM   #91
dirkwright's Avatar
Originally Posted by dirkwright View Post
A good and compact system might be an 8" coaxial crossed over to a separate 8" woofer at about 300Hz.
Here's an idea:
B&C 8CX21 (tweeter + midrange coaxial, crossover 2KHz where dispersion matches)
B&C 8BG51 (woofer crossed to midrange about 300Hz)
Box for 8CX21 is sealed @ 0.6 cu ft.
Box for 8BG51 is vented @ 0.6 cu ft tuned to 52 Hz. (-3dB is about 52Hz)
So, roughly 1.2 cu ft (34 liters) for the whole thing. Sensitivity of 8BG51 is 90 dB. The 8CX21 midrange is 92dB and the tweeter is 101dB, so some padding down is required.
Old 5th October 2011, 09:41 PM   #92
alspe is offline alspe  Finland
Originally Posted by rob g View Post
Small drivers pushed hard for powerful extended bass effect in small passive designs always sounds a little false and mechanical to my ears, usually bloated ill defined bass or overt punchy speaker effects but even the best examples usually fall short compared to closed box for my ears and I have heard many, many speakers (most are of course ported boxes) in all kinds of environments.
Ported bass nearly always draws attention to the box however Reflex has worked well in some large designs. I can see why ATC tend to avoid ported designs for their smaller speakers apart from the new scm25 speaker
Is there somekind of inconsistency in this? If you do not use port to assist bass performance, usually you will lose overall sensitivity and also bass driver works even harder (because of lacking helping port).
I'm also into closed designs.
Old 6th October 2011, 08:13 AM   #93
gornir is offline gornir  Sweden
gornir's Avatar
Here's an idea:
I’ve done co-axials in the past, mainly with Seas drivers and to be honest they are not “my cup of tea”, so to speak.
However it looks like an interesting combination for those who like the concept.
/Goran
Old 6th October 2011, 02:56 PM   #94
dirkwright's Avatar
/Goran
OK, just trying to help out.
It's interesting enough for me that I'd like to try it, except that I just finished a pair of speakers!
Old 6th October 2011, 03:16 PM   #95
gornir's Avatar
That's the joy of our hobby. We always find something new and exciting to build.
/Goran
Old 6th October 2011, 07:05 PM   #96
Ultimately I am more interested in how it sounds subjectively to my human ears than whether you are reducing one type of measured distortion, introducing out of phase bass notes, reducing cone excursion at one particular frequency or whatever.
Acoustic suspension, closed systems sound less false to me, they add less speaker effects to the music.
However I have yet to hear a properly designed ported speaker that sounds better with the ports bunged. They have to be designed for closed box operation in the 1st place.
I think a linkwitz transform used with closed boxes is a cracking way to get great bass quality and depth at the volumes most people are likely to running their speaker systems, just not for old rockers or tecno freaks who like to crank their systems "to 11" with consistent deep bass drone.
Old 7th October 2011, 09:13 PM   #97
Another very cool three way floorstander worthy of emulating...
Krypton³ | Amphion
Old 8th October 2011, 08:39 AM   #98
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Did you ever try horn midhigh transducer, there is where you will find the real highend audio nirvãna I have to be honest to you.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 8th October 2011, 09:56 AM   #99
gornir's Avatar
There is a Swedish proverb that says “smaken är som baken, delad” which means freely translated “the taste is as your but-cheeks, divided”
Nowadays I don’t fancy horn sound characteristics, but for 20+ years ago I built a lot of PA stuff, mainly with JBL, Beyma, RCF and Fane driver units. However the WAF factor tends to be low on that kind of designs.
/Goran
Old 8th October 2011, 10:30 AM   #100
Helmuth's Avatar
/Goran
My wife alway's complains about the speakers. Now with the big 50cm kugelwelle she somehow finds them not that ugly. Although she now complains other wifes find them ugly.
My horn did not sound direct good but now after optimizing the filter it is very special no horn coloring smooth spacious sparkling sound.
The gay version kugelwelle . Germans have often no taste of color IMO they also tent to do this to thier customized cars.
