I am working on some Altec Model 5's and I am not sure how to bed the repaired woofers on the sound board. They were pulled by the first owner and he used silicone when he put them back. Is that ok or should I just use putty?
#2 |
I wouldn't use silicon because it makes them to hard to remove if you ever need to. There are a variety of foam tapes (neoprene foams are a little more substantial and longer lasting) and you can always use modeling clay. Roll it out on a smooth surface until its about a 1/4' wide and place it neatly around the middle of the mounting surface. Be careful that you don't get air leaks around the screw holes.
David S. |
#3 |
You can use preformed gaskets or making it yourself cutting it from a sheet of vinyl or using auto/engine joint gaskets from your garage.
Cascade VB-5 Gasketing Foam 2.77 sq. ft. 268-278 Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll 260-540 Selleys Autofix Instant Gasket - Auto Sealant http://www.parts-express.com/pe/show...number=268-278 Last edited by Inductor; 30th September 2011 at 01:06 AM. |
#4 |
Hey, thanks David and Inductor, the gasket idea sounds like the way to go. You are also right about getting the speaker out of that silicone. I thought the speaker frame was going to bend on me. I also just got a pair of Audex (not audax) made in Winnipeg 12" 3ways to refoam. These sounded good when I put a little voltage to them but there is no info on this company. Ever hear of them?
#5 |
Here are some pics of the Audex speaks
| Installing the Right Quality Speakers in an Arcade Cabinet (replacement driver help) | tomorrow | Parts | 48 | 26th August 2011 01:09 PM |
| What Vintage Speakers to go for!?! | vintagehenley | Multi-Way | 4 | 12th January 2011 08:16 PM |
| Vintage Speakers ? | FrankRoss | Multi-Way | 36 | 8th November 2002 02:56 AM |
| Page generated in 0.08265 seconds (74.23% PHP - 25.77% MySQL) with 11 queries |
