Old 29th September 2011, 06:35 PM   #1
Default Le Cleach horn profile query
I am proposing to make some adaptors to reduce the throat of my 250Hz Le Cleach horns down from 160mm (for Lowther) down to 52mm for a 2" compression driver. When i used the Le Cleach calculator i have found that the profile does not simply extend backwards. Looking at the spreadsheet it looks as if the natural expansion routine it is using will give a different profile for every throat size. Attached is a graph showing how the profiles differ - what should i do, curve fit a profile "that smooth" from my current throat backwards or ?? suggestions please, as i dont know how sensitive the throat portion of the horn is.
i will be making flanged fibreglass extensions which will bolt on to the back of the existing horns.
Old 30th September 2011, 05:37 AM   #2
revintage's Avatar
Interesting, have never compared the flares before. What happens if you adjust T of the 2" a little to see if a better compromise can be done? Looks like it will be a real "bump" now.
Why not move this to the "Jean Michel......" thread. Think there might be a better chance to get an answer there.
Just a little note: A JBL 2" is 49mm at its end and a 50mm throat will then be what you should go for. JBLs are 5 degrees, but you probably knew.
Brgds
Lars
My Le Cleac'h horn build 3GGG Multi-Way 163 9th January 2012 09:38 PM
Le Cleach profile needed 3GGG Multi-Way 38 28th February 2011 06:32 PM
Help me simulate a Le Cléac'h horn from hornresp sqlkev Multi-Way 9 12th September 2008 08:07 AM
Le Cleach spreadsheet jdruley Multi-Way 2 24th November 2007 04:55 AM
Page generated in 0.06644 seconds (67.80% PHP - 32.20% MySQL) with 11 queries
