Best midrange to pair with Beyma TPL-150
Old 20th June 2017, 03:41 PM   #671
LewinskiH01 is offline LewinskiH01  Argentina
Originally Posted by Scott L View Post
Yes, you can always use the '45 SET for the tweeters. Guess you will have to find out for yourself. That's actually the best approach. It's wise not to believe me, or anyone else for that matter, on these discussion forums. I read through the first page of the AC post by Richard, and the follow ups. If you look at exactly how he decides it "sounds so good", based on the room set up and the approach, I would not trust the way he hears things. What a disaster.
This is probably the very best example I have seen of a novice following all these rules of mysticism. Open baffle, 6 db/oct crossovers, etc. etc.
I have included the phase and impedance measurement of my mid-range section. I don't see the dip down to 5 ohms. I have no idea where you got that (?) CHECK THAT. The file is too big to upload here. I took a picture from the screen instead. Probably can't see much from it. Darn
You are right Scott: your driver's impedance doesn't fall as much as I had seen on the manufacturer's graph http://www.tb-speaker.com/uploads/fi...113e29b0a5.pdf
Interesting driver!
Old 20th June 2017, 03:48 PM   #672
Originally Posted by manninen View Post
i dont know b&w fsts specs but here is no eq, no xo and same amp gain levels comparison
after eq i have to pad fst 5db down
FST is a great driver. I have them in my B&W and love them. They are rated at 94dB sensitivity, though, and low impedance. Impedance is low, but very flat. I remember someone measured this online. Excellent driver, but not for my application.
Old 20th June 2017, 03:53 PM   #673
Scott L is offline Scott L  United States
Interesting driver!
On the graph supplied by TB,
the db is scale is on the left, the impedance scale is on the right.
Since the very first time I heard this driver, I knew I wanted it. It just sounded "right". (and "right" is a personal subjective opinion)
Old 20th June 2017, 03:56 PM   #674
manninen is offline manninen  Finland
manninen's Avatar
yea just thinkin what sensitivity really is on those, there are 4-5 different fsts versions
measured that horn would not add any gain to 2k and tpl is 100db at 10k
i still have to -5 db fst
reason have to be that amp plays louder 3.4ohm speaker that it does 5.9ohm one?
Old 20th June 2017, 09:28 PM   #675
Indeed. I must have looked at the wrong axis. So minimum impedance is about 8ohm.
Have you heard Lowthers? How do they sound different from your midrange?
Old 20th June 2017, 09:45 PM   #676
Sadly enough, I have only heard one pair of Lowther's in my life time. It was back in the year 2004, in Austin Texas, and the sound quality was SUPERB.
If memory serves correct, they were DX-2's and mounted in ORIS 150's.
That, my friend, was a life altering audio experience and forever influenced what I wanted for myself.
It's been a long number of years ago, so I can't really compare. Both his and mine are superb. Tang Band gets a bad rap because they don't cost enough money for the snobs. AER and Voxativ no doubt, rank even higher than
superb.
I did hear some Voxativ at Axpona,Atlanta 2011, and have to say they were sublime (which ranks higher than superb)
Old 21st June 2017, 03:18 AM   #677
D OB G is offline D OB G  Australia
Im getting good results with an 18sound 8NM610.
16 ohm rated impedance.
Very efficient. Very expensive unfortunately.
Designed to be horn loaded, but Im using it on the baffle.
Crossed at 2.4 kHz to TPL150 (no horn).
Old 21st June 2017, 04:52 PM   #678
manninen's Avatar
^French test 18sound 8NM610 and rcf MR8N301
i would take 18sound over rcf
Old 21st June 2017, 07:12 PM   #679
POOH is offline POOH  United States
POOH's Avatar
I'm into real life dynamics and tone. Recipes for fully horn loaded horns systems are for me, direct radiator speakers bore me. Why have a fax when you can have vivid 3d technicolor? I love the sound of live instruments. This is my goal with my playback.
Old 21st June 2017, 08:34 PM   #680
Default 6ND410
If it were me, I'd choose the 6ND 410, build my OWN back chamber and horn load this beast !!
http://www.eighteensound.com/Portals/0/PDFs/6ND410.PDF
(Not really too expensive)
Eighteen Sound Speakers - Eighteen Sound 6ND410 - Eighteen Sound 6ND410 6.5" midrange speaker has a lightweight neodymium magnet and is 102dB SPL. Eighteen Sound 6ND410 6.5" midrange speakers are available here. 18 Sound speaker components.
Best midrange to pair with Beyma TPL-150Hide this!Advertise here!
Modeling Beyma TPL-150 Ribbon Loren42 Multi-Way 0 15th July 2011 11:55 PM
Beyma TPL-150 Just Might be Worth the Price! Loren42 Multi-Way 7 28th June 2011 09:13 PM
Beyma tpl-150 + Lambda TD12M's studiotech Multi-Way 21 24th July 2009 12:51 PM
-Beyma TPL 150 AMT flshzug Planars & Exotics 1 23rd June 2008 11:45 PM
