i ve been looking at threads for various ob and i would like to place my demands and results to get opinion from you speaker experts ...
the use : As we speak i use a couple of 2way bass reflex created with 8" visaton and one Tonsil silk tweeter xover is made passive 2ond order for woofer and 4th for the tweeter .... the speakers are placed in front of my working bench spread in 2 meters and close enough something like one meter to my ears Idea is to be able to listen detail in very low power .... speakers are wokring perfectly only drawback with this setup and these units is that midle doesnt actually kick in unless some ammount of power is given to the speaker The need : question is if i go for 10-12 " based OB will it add anything to my listening needs ? i asume that 10-12 inches will cover the diference in the bass but still one have to sugest if this playable to do or not one will may also say try and see ( OB to built is simple enough )...still could be nice to listen if one ever used the same application and results kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 29th September 2011 at 08:40 AM. |
#2 |
What, if your problem is a missing loudness correction in the first place? Have you tried to enhance bass and treble while listening at very low power?
Rudolf
www.dipolplus.de |
#3 |
First of all i dont have a problem ...meaning that i can understand if a speaker plays with low power ( low enough) not to even start the speaker poperly
its ok if i have to kick in some power ( i have plenty available ) to start the speaker as about loudness correction or any other tone controls is absolutely out of the question system is totally flat and there absolutelly no tone control involved in any way kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
Loudness that only kick in at low volumes, is actually a good idea. This have to do with how the ears pick up the sound at very low SPL.
#5 |
If you want open baffle style spacious sound in a small confined space how about copying Steinway Lyngdorf for the rear wave of the dipole tweeter operating in a side firing /opening configuration.
Steinway Lyngdorf - S-Series Speakers |
| onken as a near field monitor | togril | Full Range | 41 | 15th July 2011 12:21 PM |
| Alpair 12 with passive radiators for near field monitor? | 18Hurts | Markaudio | 17 | 28th June 2011 11:02 PM |
| Fertin field-coils in OB - again | Paul Folbrecht | Full Range | 0 | 16th June 2010 07:35 PM |
| Unusual computer near field monitor | Hezz | Multi-Way | 7 | 26th March 2008 12:00 AM |
| low cost (£70 max), near field monitor/bookshelf speaker. | Puggie | Multi-Way | 7 | 24th October 2004 09:36 PM |
| Page generated in 0.08455 seconds (75.78% PHP - 24.22% MySQL) with 10 queries |
