Is there a way to wire up 3 8ohm woofers so they come out at a fairly normal resistance ( 4, or 8)?
#2 |
No.
#3 |
Do you know what I'd get if I ran 2 in series, then paralleled them with one more? (saying that all 3 are 8 ohm) And, would the resulting odd resistance mess up my amp?
#4 |
Speakerholic
Yes, you would have more sound coming from the one than the other two. Not such a good idea unless you want to run them as a 2.5 system.
#5 |
frugal-phile(tm)
You'd get 1 woofer working a lot harder than the other 2.
I'd suggest using just 2 woofers, or using 3 amps, or using 3 in a subsystem that is a 2-way, 2 woofers below the bafflestep, 1 above. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
That'd be 8 // 16 = 5.333 Ohm
But, for woofers (in passive xover), it is not a good solution. Why not use 2 per side, and save 2 for center sub? |
#7 |
Hmm, well, maybe a nice passive radiator then
#8 |
I am in the same boat only mine are 4 ohm so I have only 1.33 ohms or 12ohms to choose from or take a loss of almost 2db and go with 2 woofers per cabinet.
jer |
#9 |
Speakerholic
Hmm, boxes often have 6 sides, why not all in one box with a plate amp?
#10 |
I have dual 10s in my current ones, and I use a very old SAE amplifier with only 2 outputs. It's a very 70s setup, but I love the bass and the power of it. You know how the greedy mind gets " if dual 10s are good, 3 might be even better!"
| 13 inch Seas woofers H175 33F-ZBX/DD woofers brand new in the box | josemedeiros | Swap Meet | 0 | 11th January 2011 01:43 PM |
| Gorlich, Micro-Precision Z130 Woofers, 5", $150 Pair, Best Woofers In The World!!! | NagysAudio | Swap Meet | 5 | 14th December 2010 06:31 PM |
| Pryamid Clear Woofers or Goldwood Heavy Duty Woofers any Good? | form109 | Subwoofers | 4 | 20th March 2010 08:59 PM |
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.09400 seconds (78.06% PHP - 21.94% MySQL) with 10 queries |
