#241 |
I would like to add one additional comment regarding active vs passive x-os. The second major argument that actives are superior to passives is based on the idea that voltage transfer function of the passive crossover will be affected by changes in the VC impedance due to temperature changes, and with an active crossover it will not be. This is true, providing the amplifier's output Z is small compared to the driver's Z. But again the implication is that the unchanging transfer function of the active crossover is better. Maybe, maybe not. The point is that the force accelerating the drivers radiating surface is a function of the current through the VC, F = Bl x I = Bl x Vapplied/Zdriver. Thus the actually transfer function of the radiating surface's motion is a function of Vapp/Zd, not just Vapp. Thus holding Vapp constant as the VC Z changes due to temperature does not imply that the acoustic transfer function of the filtered driver will remain constant.
There are lots of other issues but I think enough worms have gotten out of the can for now.
John k.... Music and Design NaO Dipole Loudspeakers. |
#242 | |
Re the other comments, I was not pointing at you (which I why I said I'm not asking you to provide proof, sorry if you took it wrongly), but the argument about damping is one that active crossover proponents commonly use as an example of all that is bad about passives and it just really isn't the case. It is those proponents that imply that lack of damping is the devil. I'm personally petty neutral on active vs passive.
#243 | |
"Driver impedance" in its common usage itself is a problematic terminus IMHO, because we lump in two mechanisms (somebody mentioned already), the true electrical impedance of the coil at the given DC excursion position in the gap (clamped cone) plus the microphonic voltage from the coil (gives a voltage proportional to cone velocity) which pickes up any motion no matter what caused it. Both are distorted, but when we do feed as little as possible of this sensor voltage back into the system, chances are better to get lower overall distortion, except at unstable / ill-defined points of mechanical driver resonance. Geometrical resonances (standing waves) tend to be stable and can be handled with signal pre-correction. - Klaus |
#244 | |
Of course changing drive impedance changes Lf response considerably and so changes excursion vs. frequency. To get around this and insure an apples and apples comparison I used one of the old B&K oscillators with the compressor (feedback loop) and connected to keep the output SPL flat (showing my age here). In fact the compressor was tracking the fundamental so that the non distorted "1st harmonic" component was dead level. I achieved high and low Z with one of the old Fisher "Z Matic" tube amps. Second and third (I might have plotted to 5th) were identical as long as the compressor held the fundamental output curve flat. This was true all through resonance +- and Octave or so. The only place where output Z made any difference to distortion was in the midrange area where there was high 2nd harmonic due to flux modulation. High Z lowered the distortion. I don't know if that agrees with Hawksford but I still have the measurements. David S. |
#245 | |
Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#246 | |
Same difference, bud. Later, Wolf
#247 | |
You optimize the xover from the impedance/FR/phase data, so you can't just say, "it's this impedance at this frequency, so I need this value L and C for this xover Fc". The Fc (corner) is selected by the components used in reference to the impedance and the dB level of the FR at that point. The Fc is where you put it with that in mind, not "shifting" if you don't do something else. Later, Wolf
#248 | |
Whether adding zobels increases or decreases the net input impedance presented to the amplifier is highly dependant on the topology of the rest of the crossover network, and how it interacts with the drivers impedance.
- Simon |
#249 | |
I was recently thinking about the possibility of a pseudo-current source network for a midrange driver, and whether there would be a worthwhile improvement in distortion. If we assume a driver that is quite sensitive and needs more than 6dB of attenuation relative to the woofer, the idea is to provide all the attenuation only via series resistance to present as high as possible source impedance to the driver. The usual shunt resistor of an L-Pad would be placed before the series resistor instead of after it, and the zobel (if needed) would also be placed before the series resistor and scaled the correct amount to still present a flat impedance to the output of the crossover at the high frequency end. Of course that imposes two issues - One would be a rise in response of the driver at higher frequencies relative to pure voltage drive, but that could be corrected for in the filter section before the series resistor, or depending on the driver a gradual rise in response may actually be desirable and beneficial if the driver already has some natural roll off. (The latter is likely with the driver I have in mind) The second issue is controlling the fundamental resonance of the driver, which will be greatly increased in amplitude with the higher source impedance. This will almost certainly require an RLC compensator connected directly to the driver to accurately correct this, but chances are depending on the driver and midrange enclosure size an RLC compensator already would have been required to flatten the fundamental resonance anyway - all that changes is that the required values will be different. So essentially we have the same number of components (assuming both zobel and resonance compensator were wanted in the more conventional configuration) but the question is, is it worth the trouble ? I guess it depends entirely on the individual driver, both in terms of how much attenuation it requires (and therefore how closely you can approximate current feed) and also in terms of how much L(e) modulation it has. I'm also assuming it would be fairly pointless for any driver with a copper shorting ring.
- Simon Last edited by DBMandrake; 6th October 2011 at 08:43 AM. |
#250 | |
As for the Dynaudio BM5a, they are absolute crap compared to the passive version with a good amp. They use car audio electronics and the passive version on a cheap used Bryston sounded waaaayyyy better. I could be wrong but i think you're confusing active speakers with active crossovers. |
| Passive Crossovers, Two Amplifiers | davidbosch | Solid State | 1 | 19th January 2011 09:34 PM |
| passive crossovers.... | stuman | Subwoofers | 10 | 8th December 2009 02:44 AM |
| why do we bother with passive crossovers? | paulspencer | Multi-Way | 70 | 13th September 2004 07:06 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Solder for passive crossovers. | JoeBob | Multi-Way | 8 | 31st December 2001 04:28 PM |
