Old 28th September 2011, 08:59 AM   #1
Default Tweeter opinion
Im looking to build a line array for a big home theater.
My main speakers cant keep up with the 8000 watt (Peavey 4080's) sub system.
I was thinking side by side 4" Dayton RS100-4 (8 of them) with XT25/60's Vifa tweeters (8 of them also per side). In a 2 cubic foot box it should extend to -3db at 55hz but will be crossed actively to the subs over 80hz LR4.
Tweeter crossed over at 2700 to 3000hz 4th order (active crossover with separate amps). I figure the use of 8 of them will also lower distortion by a fair amount.
How would the XT25 sound? Most who slam it seem to have issues from the crossover being too low. I can go with a more expensive tweeter if I have to but I dont want to. I have 2 new XT25s already but havent heard them yet.
Old 28th September 2011, 10:20 AM   #2
norman bates's Avatar
lol, if you really listen that loud, you should look into compression drivers and horns, maybe even dual compression drivers y'd into 1 throat. Maybe even horn loaded 12's....
Norman
Old 28th September 2011, 11:42 AM   #3
Norman
A guy asks a question about the SQ of a tweeter and you suggest compression drivers for SPL?
The system is also for low level music where accuracy is wanted. Line arrays have been described as pinpoint imaging. It has to be musical.
I appreciate the input but not what I'm looking for. Im looking to 16 tweeters to handle the power that I have two doing now.
Old 28th September 2011, 12:42 PM   #4
doug20 is offline doug20  United States
. Line arrays have been described as pinpoint imaging.It has to be musical.
Its funny to read that because I have read many opinions that say line arrays are actually inaccurate designs that cause too much lobing, etc.
Also the directivity isnt great at all. For HT I would not consider a line array at all. Build a quality waveguide design and have the best of both worlds.
Old 28th September 2011, 02:44 PM   #5
18Hurts is offline 18Hurts  United States
I just built a set of arrays with twelve 5" woofers and forty-eight 10mm dome tweeters and have a few thoughts.
The first thing is the drivers must be packed together tightly, the giant flange on the XT25 causes the tweet to be larger than the woofer. It measures out at 4.125" which would cause beaming issues. For this reason, most 2-way arrays use the smallest tweeters possible packed together. Mine are packed at about 1.45" center to center and crossed at 4,300 Hz to make about a 6 foot tall vertical line.
The 2-way arrays are very efficient, very loud beasts with a huge sound stage and overpower early reflections in my garage. I would not describe them as pin point imaging, that is not "their thing". A great design for bad acoustical spaces when SPL is required with minimal floor space available--I would gather more of a PA type speaker than one for critical listening. When doing actual work in the garage, my ears can be near the floor, sitting down or standing up and the 6 foot tall array works well for that application over point source. It is hard to critically evaluate a speaker in a metal garage with cement floors and sound reflecting off mowers, tool boxes and various things in the rafters.
In your research, read information from people that have actually built, tested and measured the things to help clear up the smog. The best thing would to actually listen to a set but they are a rare site to behold. Arrays are more of a PA speaker type device and Keele's CBT system is still in prototype it seems. They are entertaining to listen to psycho-acoustics in action though--no computer simulations for how the brain accepts, rejects or changes sound on the fly.
Old 28th September 2011, 07:43 PM   #6
8 bilion watts, now that has to be loud -> or not.
Prior investing into this,
maybe you could post how many dBL does that sub manages.
Most probably you do not need 16 alien ant farm sized tweeters and 16 trucks of midbass units.
Besides, the more sources you have the most likely it is hard to make them work well along.
Allso do make sure to post the filter slope and corner freq. for that sub.
Along with an unfiltered response graph.
probably afterwards some handy advice could be given.
8000 watt does not describe how loud is should be.
Old 29th September 2011, 07:09 AM   #7
Its kind of irrelevant how it measures. The fact is, the limit was the burning tweeter I had. I just need more power handling on the mains.
Old 29th September 2011, 07:14 AM   #8
Thanks to all who posted.
I appreciate the logistical warnings as to line array theory but Im not asking those questions here. I wish I could edit the first post to delete everything and replace it with this one question:
HOW WOULD A VIFA XT25 SOUND CROSSED OVER AT 2700-3000HZ with an active crossover using 24 to 48db/octave?
Old 29th September 2011, 07:20 AM   #9
Interesting points.
People have used 5" woofers with 6" tall ribbon tweeters in their arrays so I didnt think the 4.125 tweeter would be an issue.
I guess a 94mm faceplate would make a better choice like a Morel MDT30S but the cost is double on the tweeter side and I dont think it has the top end of a ring radiator. Im willing to go more money. I'd still like to know about the XT25. I have 4 of the RS100's and 2 of the XT25s already. I threw together a .28 cubic foot test box to run one of each and will see for myself if its worth pursuing. It will be measured but I need 2 for listening tests. I guess I was looking for a confirmation not to waste my time if someone factually already did a 2700 24db/oct build with them. I guess I was thinkinbg that each of 8 XT25's doing 1/8 the work would sound way better than singles crossed at 2000-2500.
Dare I say that Zaph's test of it with it not doing well under 2k for HD is likely 80% of the hate of the tweeter by people who never used it themselves. Zaph has always been right. He warns of ribbon tweeter issues and I ignored that. I built it and like it while im in the sweet spot and hate it everywhere else. He used this XT25 in what he calls a referece level system so it has to have merit. Im with him on this one and have no intention of using a 2k crossover point hence the RS100 for the midbass.
Can you post pics of what you built? It sounds awesome.
Old 29th September 2011, 07:34 AM   #10
One interesting tidbit of info: Im at 6800 feet elevation and speakers dont play as loud here due to air density being 28% less. Less air to move= less sound made from shaking it.
Thus, my system eats more watts to make the same SPL at sea level. This makes you hit the thermal limit of any driver sooner with less spl.
crossing over from tweeter to tweeter, mid-size tower concept scape Multi-Way 5 7th April 2011 08:43 AM
Tweeter Mount & Diamond Audio Aluminum Tweeter cnp112 Car Audio 0 18th November 2010 05:35 AM
opinion about this "tb" tweeter hobby1 Multi-Way 4 2nd June 2005 02:29 PM
opinion oldbar Multi-Way 11 25th May 2005 05:25 AM
Tweeter Opinion jchappj Multi-Way 19 20th November 2004 02:50 AM
Page generated in 0.13236 seconds (83.76% PHP - 16.24% MySQL) with 10 queries
