Old 27th September 2011, 09:38 PM   #1
Default hard cones resonance and induced harmonic distorsions
Hi guys,
Someone to explain me in simple words how "sharp peaks at a particular frequency will always cause a peak in the 3rd harmonic distortion plot roughly 2 octaves below" (quote from Zaph) as harmonics do always appear higher in frequencies ?!...
Zaph inside:
crazyhub
Old 27th September 2011, 09:48 PM   #2
Simple. At any frequency 'f', a driver having 3rd order HD will actually be producing sound at 3x f, or 4x f for 4th order, or 5x f for 5th order, etc. If the driver is more sensitive at 3x f, 4x f, 5x f, etc. this will result in higher apparent HD down low... but in practice, because peaks will be notched out, the distortion will not be as bad as it seems for an unfiltered driver.
I'm in the camp that distortion tests should be done on drivers with equalized on-axis responses, but this requires quite a bit of work.
Old 27th September 2011, 09:57 PM   #3
apparent? so not real/actual?
crazyhub
Old 28th September 2011, 12:51 AM   #4
It is real if you run the driver without any filtering. Most designers take out the cone resonance peak before doing anything else with it.
Oh, and 2nd and 3rd order HD is not nearly as harmful as 4th, 5th, and higher, except in sub applications where any HD will serve to localize the sub.
Old 28th September 2011, 04:03 PM   #5
Thanks 454Casull for the explanation.
<<<< except in sub applications where any HD will serve to localize the sub.
*** interesting...and obvious.
crazyhub
Old 28th September 2011, 05:03 PM   #6
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
“Someone to explain me in simple words how "sharp peaks at a particular frequency will always cause a peak in the 3rd harmonic distortion”
Sure.
The amplitude response curve assumes that the driving force is held constant. What one sees then is that there is a broad flat area where the system is an acceleration limited system. In this region, if you were to glue a lead ring to the voice coil, you would displace that flat part of the curve downward resulting in a lower LF corner and lower efficiency (but no change in the hf response). As one goes higher in frequency, one can see the level falling a bit as the cone is no longer able to fully act like a ridged piston and is less effective.
Higher up is cone “breakup” where cone is in mechanical resonance, the first peak generally being when the outer edge is moving farther than the center / voice coil.
With higher modes, part of the cone is going one way while other parts the opposite direction.
Above this region, the bulk of the cone is mechanically decoupled from the voice coil in addition to the inductive roll off.
The bottom line is that the peaks represent acoustic gain over the surrounding area’s and so if one has a mound of “excess gain” at say 1200Hz, then one also has the situation where the motor nonlinearity is also amplified accordingly at that frequency. Remember if the signal is at 500Hz, the third harmonic produced is at 1500Hz. So, if one has a motor linearly that would produce 5% distortion at a given F and level and a gain of say 20dB at some frequency, then one knows that at frequencies of half, 1/3. 1/4 1/5, 1/6 etc of that gain, the natural harmonic content from the motor will be amplified that same 20dB or be 10X higher or 50%. I used 20 dB because it’s easy to scale being 100X in power and 10% in percentage distortion.
It might seem that that using a sharp crossover below the misbehavior would “fix” this and it does so far as the amplitude response BUT the increase in distortion remains because it is at those lower frequencies are where the distortion is produced and the mechanical system still has that gain..
As most of a loudspeakers problems get louder faster than the input signal loudness, reducing a speakers distortion for a given level often results in a higher usable loudness. At work, we make speakers for large spaces and there all of the loudness and room acoustic related problems are what shapes modern sound system design. The direction we went is to use a point source CD horn driven at multiple points based on the frequency / size of the wavelength within the horn. For the ranges below the HF section, each range is coupled to the horn through an acoustic low pass filter.
This is comprised on the air mass in the port leading into the horn and the air volume trapped between the cone and baffle board. This reduces the distortion a driver produces by attenuating the output at a second order slope above the desired upper frequency limit.
In the case of the Synergy horn an additional distortion reduction mechanism is that well above the size governed operating range, the distortion components cannot drive the horn with “gain” and instead are attenuated by a series of cancellation notches which begin when the side mounted driver is ¼ wl from the closed end.. Fwiw, It was exploration of this cancellation notch and the thought “what if I substituted a source of the opposite phase? ..which I had in the back side of the same driver” that lead to the computer model, that lead to the Tapped Horn .
The simplest band pass subwoofer alignment also has a low pass effect, it has an acoustic low pass effect and would radiate less distortion for a given SPL than the same driver as a direct radiator.
The driver’s motor linearity appears to be the dominant “thing” governing distortion over a broad band.
It is the balance between low cost, high strength to weight and internal damping which limits the Q of breakup features, that makes paper pulp popular even in 2011.
Headroom is your friend.
Best,
Tom Danley
Danley Sound Labs
Bring back mst3k and futurama
Old 28th September 2011, 05:21 PM   #7
Smile Thanks Tom
Hi Tom.
As always your posts are just great! Hidden gems as well as the main point.
Thanks for taking the time to add to the forum. There are plenty of very clever doctors, dentists and scientists from all walks of life on this site, many are even have commercial audio interests and a few might actually have sold a few $ worth of their ideas..
But your CV and PROVEN theories in the $millions count for so much more...
I trust the opinion of 1 expert over a 1,000 well-meaning amateur audio professional doctors any day.
Humbly in awe
Derek.
Old 28th September 2011, 09:53 PM   #8
Thanks a lot Tom for your input!
Originally Posted by Tom Danley View Post
...It might seem that that using a sharp crossover below the misbehavior would “fix” this and it does so far as the amplitude response BUT the increase in distortion remains because it is at those lower frequencies where the distortion is produced and the mechanical system still has that gain..
Does the distortion also occur at these lower frequencies?
crazyhub
Old 29th September 2011, 04:51 PM   #9
Crazhub asks;
“Does the distortion also occur at these lower frequencies?”
Yes. Picture that when the speaker radiator moves in and out in a perfect sine wave motion, it only produces sound at that one frequency. If you did anything like touch it with your finger, you would be changing what it did in one place in it’s motion vs another and so you have added a non linearity.
The motion would then be not a pure sine wave and contains energy at other frequencies as well as the real signal.. In the real world, nothing is perfect and say with the loudspeaker, one has much greater non-linearity than with the electronic part. Non-linearity is anything / everything that causes what the system does to be different that what it is told to do. Non linearity causes “free sound” to be produced, this is energy that is not in the drive signal.
So, if one drove a speaker with a “pure tone” at 300Hz, the driver nonlinearity would be adding energy at 600Hz (2nd harmonic), 900Hz (3rd harmonic), 1200Hz (4th harmonic) and so on. It would be these harmonics that if they fell where one of those mounds of excess gain were, that would be amplified by that amount.
In Radio work, THD or Total Harmonic Distortion made perfect sense because one doesn’t want energy outside your assigned frequency and harmonics are signals produced by the nonlinearity which end up at even and odd multiples of the fundamental (intended) frequency.
In audio, back when some amplifiers had gross distortion and all of them had more similar properties (as they were all tube based) THD still made some sense.
Later work into audio compression revealed more about how we hear.
Read about perceptual masking for example, it governs if we can hear a particular sound in the presences of another sound, this plays a strong role in our hearing but one we are unaware of as it is all we know.
Psychoacoustics - Wikipedia, the free encyclopedia
The bottom line is that best case against a silent background one cannot hear a 2nd harmonic until it’s quite large but as the harmonic number rises, harmonics become easier to hear. The result is that THD in this case is not very useful as it doesn’t represent how we hear or how that changes with frequency.
Not only that but music is harmonic in structure so the even harmonic part of the spectrum doesn’t necessarily sound out of place. During the recording process since the Beatles, even order distortion is often added to make a “richer” sound. On the other hand, natural sounds are usually not harmonic and so then adding either even or odd order distortion can change the sound.
Overkill Audio said;
“Thanks for taking the time to add to the forum etc.”
You welcome but don’t get the wrong idea, anyone can have a good idea.
I write these things in part because my background is a DIY speaker builder and have loved audio stuff and electronics since childhood.
It is places like this where the seeds of tomorrows audio are sprouting / growing, the place the people who will take jobs like mine when I retire come from.
Best,
Tom Danley
Mike has posted a humorous video of a demo he did Tuesday;
The 3 speakers are the small black blob under the scoreboard and to the right. Try it with headphones.
Danley Sound Labs, Inc.&#039;s Videos | Facebook
Old 29th September 2011, 05:29 PM   #10
DrDyna is offline DrDyna  United States
DrDyna's Avatar
That video makes me want a couple of your DTS-10's Tom, lol. *sigh* maybe someday.
soft vs hard mid-woofers cones: audible directivity characteristics? crazyhub Multi-Way 43 13th January 2012 09:30 AM
line-array vs conventional point-source/ distorsions issues crazyhub Multi-Way 26 2nd July 2007 12:03 AM
Distorsions in class D ChocoHolic Class D 132 28th January 2007 02:33 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 11:37 AM
Zen v4 and bass distorsions ... Stabist Pass Labs 4 24th September 2002 11:59 PM
Page generated in 0.14438 seconds (84.05% PHP - 15.95% MySQL) with 10 queries
