Have at it.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#2 |
There must be some interest?
A 3-way sheet is possible as well, but many compromises need to be made to get decent SPL.
#3 | |
John L.
"...His brain is squirming like a toad..." Jim Morrison |
#4 | |
Did you experience any floor bounce effects?
#5 |
It says 22 views
Good job, I like it. I will probably use at some point. I am not very clear on how to calculate the frequency where the dipole starts to bring down the low end response. Can you please explain how it's calculated? -- As for recommendations I will suggest making some interactive graphs even if they are pretty simple. There's no substitute for being able to see instantly how changing one parameter affects the rest of the system. |
#6 | |
The low end only starts to suffer as dipole loss increases - and Tolvan's Edge should be used to verify how bad the effects are. If you are asking how the equations are derived, I cannot explain. The equations are taken from Mr. Linkwitz's work.
Building a 2.1 system out of a 3/4"x4'x8' sheet Last edited by 454Casull; 27th September 2011 at 08:16 PM. |
#7 | |
How to Tell How a Speaker Sounds in a Room: (Supplement to REG's review of the McIntosh XRT28s) ![]() vertical directivity "compromise" I see as a plus in 6' tall speakers... John L.
#8 | |
And I was wondering about floor bounce from within the same driver - i.e. from top to bottom, is there any destructive interference?
#9 | |
no
#10 |
Updated
| Wanting opinions on first OB build | happyb | Multi-Way | 8 | 21st September 2009 12:21 PM |
| Wanting to build amp | systemerror909 | Pass Labs | 13 | 2nd July 2008 07:13 AM |
| Wanting to build a mic mixer | DeadSpeaker | Everything Else | 1 | 27th October 2007 02:03 PM |
| Newbie, wanting to build Amp | PaulHilgeman | Solid State | 3 | 8th January 2003 02:24 AM |
| Wanting to build an hdtv tuner | Shaun Perez | Digital Source | 13 | 31st October 2002 04:03 PM |
| Page generated in 0.13210 seconds (79.40% PHP - 20.60% MySQL) with 11 queries |
