Old 26th September 2011, 03:15 PM   #1
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Default Double chamber reflex 3-way
I've knocked together a pair of 3-ways in dual chamber reflex enclosures. The main chambers are 59L and were originally passive sub cabinets. The second chambers of 19L are grafted on to the subs with a port connecting the two. Both external ports exit to the back.
The drivers are:
Woofer: 12" GDN300 4 ohm SPL 95dB
Mid: HiVi DMA-A 50mm soft dome
Tweeter: Visaton G25FFL
Waveguide: Visaton 220x150
The XO points are 800/5000Hz, 1st order on the woofer and 2nd order on the mid and tweeter originally with no attenuation. The clarity and presence of vocals was impressive with a crisp breathy quality with little sibilance. The downside was a 'loss' of bass. To correct the imbalance I attenuated the mid and tweeter by 3dB which seems about right.
Efficiency is high and has already been a cause of complaint from the neighbours.
Overall dimensions (mm) H1000 x W340 x D350
Visaton waveguide
Visaton G25FFL
Double chamber reflex - why is it not used more often? River757 Multi-Way 39 3rd January 2011 02:28 PM
DCR Double Chamber Reflex Subwoofer gpsmithii Subwoofers 0 3rd September 2008 02:15 PM
Double chamber reflex rebellion Hezz Multi-Way 13 25th February 2007 05:58 AM
Double Chamber Reflex Vent Question Guss Multi-Way 16 26th June 2004 07:44 PM
quick question about double chamber reflex nobody special Multi-Way 3 11th June 2003 04:54 PM
Page generated in 0.06942 seconds (71.08% PHP - 28.92% MySQL) with 10 queries
