need 2 way crossover point advice
Old 26th September 2011, 03:11 AM   #1
dc1005 is offline dc1005
Default need 2 way crossover point advice
im looking a doing a 2 way setup, im interested in vifa ne95w-04 3in and vifa ne25vtt tweeters.
i've seen calculators online plugging in freq and giving a parts list, i need help on choosing what point and slope for this set. they will be backed up by 6 1/2 woofer, not sure which one yet the vifa ne series is a little pricey.
im going to try them out in a set of kick panels in my dodge magnum, as a trial and will this set and the door midbass will have separate amps.
ive seen some setups with exact same hp and lp values, and some with 12db hp and 6db lp with underlapping values.
another concern is tweeter protection, and will a polyswitch be needed.
i'm new to this forum, but have enjoyed audio for many years, worked as a 12v audio tech for 14yrs, and was laid off 3 yrs ago, working as a security tech now, and want to get back into owning a nice setup.
thanks
dc
Old 30th September 2011, 12:13 AM   #2
PeteMcK is offline PeteMcK
both those drivers have a hump at ~ 2khz, so some underlapping at this crossover freq would be a good idea.
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
need 2 way crossover point adviceHide this!Advertise here!
Crossover point jaudio Car Audio 1 14th September 2006 07:23 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 06:48 AM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 05:14 AM
A better crossover point Westrock2000 Multi-Way 9 26th October 2002 06:13 PM
Sub crossover point AudioFreak Multi-Way 2 31st December 2001 12:33 PM
