can anyone tell me if there is a 96DB Woofer for home use that can handle a 150-200w RMS amp ?
i only find Pro woofers that can do it. |
#2 |
Depends on where (and why) you put the limit between pro and home drivers...
And it also depend on the frequency range you are trying to cover. TAD TL1601 or AE TD15M would probably be good candidates. |
#3 |
#4 |
sorry i did forget some details , 8" woofer 40-200hz
#5 |
Custom Title
Nope!
8"s that do 96dB don't do 40, more like 100Hz bottom end if you're aligning for most bandwidth on the 8", and need a dedicated 12-15"woofer.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#6 |
My processor has a bass limit setting; I’d be going through drivers every month with it. HT action scenes: Gun fire and Explosions – yikes! (Sending 200 watts to each 8” sub).
#7 |
not an 8 incher but the rest is there
AE Speakers --- Superb Quality, Unforgettable Performance, Definitely. TD12M Highlights: Pro Style Bass-Mid or bass horn PVA Hand Coated Cloth Edge Very Light, Stiff, Hand Coated and Sealed Paper Cone 6mm peak xmax, 40Hz~2Khz, 96dB@1w, 8ohm only T/S Parameters: FS: 33.3Hz Qts: 0.25 Vas: 176L Z: 8ohm 1WSPL: 95.8dB Pe: 500W continuo |
#8 |
i use an equalizer for music bass level is unchanged 0 db, i only cut mids 2db and treble 5/6db but i listen loud.
#9 |
In the case of the TD12M you mention above, a closed box alignment with a Q of 0.5 will give you a resonance frequency of 66.6 Hz at a -6 dB level. A Q=0.707 alignment will give you a resonance frequency of 94.2 Hz at a -3 dB level. These levels are anechoic, therefore they will be better in an actual room, still they are unlikely to cover the LF extension you seek. You will have to use reflex loading and/or a woofer with a lower resonance frequency.
#10 |
i have 2 active subs to take care of business under 80hz , whatever i choose will replace my old JBL woofers that went down to 40hz but with lower spl 90db , i´m looking for something with better spl cause the jbl speaker always sounded to bright for my taste. i believe that woofers 96db , mids 92s db and tweeter 90 db is the best choice for my taste and room.i´m also concerned that the replacements behave good in midbass. the jbl woofers are good but they cant stand the volume levels i sometimes listen , i already replaced them once.
| Fabric Dome Tweeter 96db - altern. to Glockenklang phenol 99db (based to RCF TW116)? | tiefbassuebertr | Multi-Way | 5 | 24th April 2012 10:46 PM |
| JBL car woofer for home use | Vaughan | Subwoofers | 9 | 24th April 2011 10:51 PM |
| DCGold fullrange cones 35hz -3db @96db sensitivity?? | human.bin | Full Range | 20 | 26th February 2010 01:34 PM |
| Home Theater Sub Woofer Selection/Design | walt2 | Subwoofers | 9 | 10th November 2009 08:59 PM |
| help on home woofer | DayG|o | Multi-Way | 0 | 11th August 2004 04:47 AM |
| Page generated in 0.10048 seconds (80.39% PHP - 19.61% MySQL) with 10 queries |
