Symptoms of Overstuffing enclosures?
Old 2nd September 2003, 04:28 PM   #1
drfrink24 is offline drfrink24
Default Symptoms of Overstuffing enclosures?
What are the symptoms of overstuffing a well braced cabinet?
Given that the stuffing still allows free movement of the drivers.
Old 2nd September 2003, 06:19 PM   #2
On Hiatus
SY's Avatar
Loss of bass.
Increase in even order harmonic distortion.
In combination, an ill-defined "stuffy" sounding bass.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd September 2003, 06:45 PM   #3
This is good news! I'll remove the eggcrate stuffing from most of the interior of my Kit 281's tonite, and only stuff them with the recommended amount.
Hopefully, this will improve the bass/midbass.
Thanks for the reply!
Old 2nd September 2003, 07:03 PM   #4
On Hiatus
SY's Avatar
I'd recommend measuring the impedance before and after, just to see if you've hit the target Q that you're after.
Old 2nd September 2003, 08:06 PM   #5
Sadly, I have no actual equipment for measuring anything, except for a radioshack SPL meter for sound level calibration...
Old 2nd September 2003, 09:26 PM   #6
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Perhaps this can help
http://www.epanorama.net/documents/a...impedance.html
http://sound.westhost.com/tsp.htm
It has instructions and doesnt require any special hardware to do it
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 3rd September 2003, 01:39 AM   #7
Dave Jones is offline Dave Jones  United States
Default Re: Symptoms of Overstuffing enclosures?
Id sound like id god a code in the nodes.
Davy Jones
Old 3rd September 2003, 01:40 PM   #8
Tore out all of the eggcrate. I'm not going to make any judgement until I listen to them for a while.
Old 3rd September 2003, 02:10 PM   #9
On Hiatus
SY's Avatar
Just make sure you don't go too far in the other direction; at least having the walls lined is a good idea. Then you can vary the amount to hit the target response- or please your ear.
Old 3rd September 2003, 02:55 PM   #10
I used the exact abount of polyfill that the plans called for. 6 oz behind each woofer, and, 12 oz in the bottom chamber.
Symptoms of Overstuffing enclosures?Hide this!Advertise here!
need help with first sub enclosures NallaN Subwoofers 4 20th January 2008 06:08 PM
ReVox B226, B226-S CD repair tip - (weak laser symptoms) Steerpike Digital Source 1 26th March 2007 07:09 PM
valve wear symptoms? testarossa2k Tubes / Valves 9 15th January 2007 05:42 PM
enclosures.. Keyoke Chip Amps 20 23rd November 2006 05:08 PM
audible or noticeable symptoms of oscillation? federico moreno Solid State 17 13th February 2006 09:45 AM
