Hi, I'm posting on this forum after a long time. I'm from India and here it is very difficult for diy'er to get decent drivers. Recently I stumbled upon these drivers from a vendor who claimed it to be surplus peerless Denmark drivers..apart from this no specs or data sheet.The only technical spec marked impedance 4 ohms ..
Another detail marked on this driver is Cat no 830608 and Qc 010930. It is a 5.5 inches driver Have anyone of you used this driver. Do anyone have a data sheet(T/S parameters) of this driver?. It looks like a midwoofer to me,but i'm not sure abt this. I have searched the web..parts express..peerless site and what not, but no success. And Plz dont tell me to try measuring the T/S parameters myself ,i shudder at that thought. My only hope is someone on this forum will identify this driver and help me with the specs to build a loudspeaker..thanx |
#2 |
Looks very much like an OEM product to me, so I'd e-mail Peerless to see if they're willing to provide spec's for you. They usually are.
But from what I can see, since it has Nomex cone, current basket design, added bucking magnet, and 4 ohms, it might be from their now discontinued top-of-range line of car audio speakers. |
#3 |
Another reason for the bucking magnet is magnetic field cancelation for use around CRTs. Could be old TV removals.
Doc p.s. heres a link to some similar peerless speakers Peerless - Midrange, Fullrange, Woofers, Subwoofers, Car Audio, Paper Cone, Aluminum Cone, Glass-Fibre Composite Cone, Nomex Cone - Available at Parts-Express.com
Ne timeas a facie mulierum ea ignorare Last edited by thaumaturge; 21st September 2011 at 08:58 PM. |
#4 |
#5 |
Could be New Old Stock. To the best of my knowledge the primary reason for tacking a second magnet on the back of a driver is to cancel magnetic field for use around CRTs. CRTs are now mostly going away. Companies don't spend money on parts that aren't needed. Occams razor says the speakers were intended for use close to a CRT.
Hope the link was at least useful Doc
Ne timeas a facie mulierum ea ignorare |
#6 |
Peerless does not and has not produced any speakers with bucking magnets intended for use close to a CRT without the additional steel shielding. Bucking magnets on drivers have other uses than purely to prevent stray magnet fields.
#7 |
The bucking magnet is NOT for shielding. When one attaches a similar magnet to a driver with repelling pole, then it produces a shielding effect...which is not in this case...I have seen Philips drivers with similar arrangement
#8 |
Maybe I'm not reading it correctly, but I think that the Qc date is 2001 (010930). Are you sure about the nomex cone?
#9 |
thanx for your effort Satrunus...Looking forward with hope that Peerless people respond
#10 |
Note the date on this ID label
2001 is the most likely date. MJ One is the most likely product the driver was in. I got started at This thread - page 2 Reutilization of the MJ-One Sound System Started with Google "peerless 830608".
Striving to remove some ignorance every day (always starting with my own) |
| Can anybody identify these vintage drivers? | Jim85IROC | Multi-Way | 3 | 15th February 2012 03:07 AM |
| Who can identify these drivers? | Djim | Subwoofers | 12 | 9th August 2011 08:49 PM |
| Can anyone identify these drivers? | NewVintageNut | Multi-Way | 9 | 23rd January 2008 02:05 PM |
| Can anyone identify these drivers? | Brisso57 | Multi-Way | 0 | 12th December 2007 09:03 AM |
| Can you identify these cheap drivers? | seangoesbonk | Multi-Way | 12 | 23rd November 2002 02:21 AM |
| Page generated in 0.10039 seconds (77.58% PHP - 22.42% MySQL) with 11 queries |
