Any opinions on these two drivers, and which one would be “better” choice for DSP controlled active 3-way speakers?
I could not find much on SS, not popular or new? |
#2 |
I've used both and both are superb drivers. I wouldnt consider either "better" than the other, more a matter of your specific needs and preferences.
Crossover points may be the deciding factor. The SS12MU is a true midrange (4") - foam surround, aerodynamic neodymium motor, excellent detail from the light cone throughout the midrange, but which struggles below about 200Hz. The AT15h (5 1/2") is a bass-mid which is very neutral and can go below 100Hz, but which struggles above 3-4kHz and gives up some of the upper-mid detail. |
#3 |
Thanks David,
On the off chance that you may have had some exposure to ATC, what would be your thoughts on ATC sm75-150 versa SS12MU, would SS12MU be capable of comparably open, dynamic and detailed sound? |
#5 |
Franco, yes you're right. I was thinking about the 15h5206sdk.
Sashav, sorry I havent had an exposure to the ATC. In my experience with domes, they tend have a little more low-level detail and transparency but lose out on dynamics and usable bandwidth. |
| FS: Scan-Speak 12MU | sunandmoon | Swap Meet | 0 | 16th September 2011 04:05 PM |
| HELP Schematics for RL 12 T 15 | tubeman813 | Tubes / Valves | 9 | 18th May 2010 08:51 PM |
| FS: C-Quenze 18H52, SS 15W, 21W, 9700 | echo | Swap Meet | 5 | 4th January 2006 02:41 AM |
| 12'' or 15'' 2.5 way | Chris8sirhC | Multi-Way | 1 | 7th July 2005 09:08 PM |
| Philips 12.1T/06 Mechanism | stj | Digital Source | 0 | 28th April 2004 01:19 AM |
| Page generated in 0.08643 seconds (69.91% PHP - 30.09% MySQL) with 10 queries |
