Old 21st September 2011, 04:33 AM   #1
Default Notch filters in series xover
Would using a series notch filter tuned above the crossover freq of a series xover cause problems? i.e. the filter would be bypassing the driver and passing those freqs on to the other driver element. So, where you would use a series notch in a parallel xover, you should use a parallel notch in a series xover…???
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 21st September 2011, 05:34 AM   #2
AllenB is offline AllenB  Australia
Since not only do series crossovers pass on the driver electrical differences, but are limited in their abilities to correct specific driver needs due to the need to be symmetrical, it stands to reason very broadly speaking that a driver should be response compensated and then impedance compensated in a self contained manner before it sees a series crossover.
If I were to go that way I think I'd prefer to simulate in order to reduce the complexity of such a crossover.
By the way, I don't see the parallel and series crossovers as opposites. One has independence and the other does not.
Old 21st September 2011, 10:28 PM   #3
thanks for confirming my suspicions Allen, my reason for contemplating a series xover was the lower DCR of the smaller inductor (2nd order), but having to use a parallel notch would blow that one out of the water... oh well, back to parallel xover, have to wind a few more turns onto the inductor....
Old 23rd September 2011, 07:42 AM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Everything you add in a series xo effects both drivers. Even a simple zobel on a woofer can cause problems with the tweeter roll off such as extending it's lower end towards it's Fs. See pics of FR when a zobel is added to the woofer and it's effect on the tweeter. A series notch is not as bad AFAIK but still can cause other issues.
Unless the drivers are extremely well behaved I tend to use AR series crossovers where any mild peaks in the woofer roll off can be handled via the large inductor and the cap size in the zobel.
With series xo's, driver selection is very important as very little correction can be achieved.
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Help on series notch filters. bowdown Multi-Way 1 9th March 2005 05:51 AM
Page generated in 0.07626 seconds (71.68% PHP - 28.32% MySQL) with 11 queries
