Constraints:
- overall diameter must not exceed 100-110 mm - must be able to handle power bursts such that at least 105-110 dB/1 m peaks are produced in the passband into full-space without melting or audible distortion - distortion performance between 700 Hz - 1500 Hz must be very good or excellent; FR88EX qualifies, TB-1558SE qualifies, Aura NS3 does not qualify - must not have a waveguide or horn - costs less than $150 in North America Closest I can get is the Scan-Speak 10F/4424G00... however, its distortion performance is only good (and not excellent), and its power handling is barely passable. On the other hand, a dome mid like the TB-1558SE has excellent distortion performance but may not be able to produce the SPL bursts I want, and has a very large flange to boot. The FR88EX has a lot going for it, like its great distortion performance, small flange, and low cost, but doesn't quite fit because of its power handling/low sensitivity.
Building a 2.1 system out of a 3/4"x4'x8' sheet Last edited by 454Casull; 21st September 2011 at 02:30 AM. |
#2 |
Your question is meaningless without knowing what woofer, tweeter, and enclosure type/arrangement you are trying to build.
#3 | |
Have you seen this measurements write up on the SS 10F? It sounds like the specs are rather conservative and this driver can take some abuse. |
#4 |
Were my constraints not enough information?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#5 | |
However, it looks like the Dayton RS100 might be a contender as well. The Vifa NE95W has potential but it's new enough that not a lot of info is available. EDIT: On second thought, the RS100 has up to 10 dB more 5th-order HD in the range I'm looking at, according to Zaph's test data, which lands right in the high-sensitivity region. Too bad I don't know what the test environment is like for his blog measurements...
Building a 2.1 system out of a 3/4"x4'x8' sheet Last edited by 454Casull; 21st September 2011 at 03:00 AM. |
#6 |
Interesting driver, what do you think. It's always funny to have this kind of quiz @DIY.
Eton 4-200/A8 Symphony, 4" Mid/Bass with Aluminum Former: Madisound Speaker Store Voice coil former ; Aluminium. Last edited by Inductor; 21st September 2011 at 12:15 PM. Reason: mec |
#7 |
#8 |
You are asking a lot of such a small driver. I think this one should work well:
FaitalPRO - Professional Loudspeakers Made in Italy Faital Pro 4FE30.
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
| Going 4 way - low mid / mid horns | Speedysteve7 | Multi-Way | 10 | 15th April 2011 07:13 PM |
| How do you select a dipole Mid (800-3000Hz) – eg does QTS matter? | charliemouse | Multi-Way | 8 | 7th July 2007 11:37 PM |
| Help to select the design | denbo123 | Multi-Way | 6 | 30th June 2006 10:06 AM |
| How to Select an Enclosure | BAM | Subwoofers | 8 | 9th April 2005 03:44 PM |
| What are some decent drivers for a small/mid size center channel speaker (1 mid,1 tw) | kehi | Multi-Way | 24 | 21st December 2003 08:10 AM |
| Page generated in 0.10908 seconds (79.66% PHP - 20.34% MySQL) with 11 queries |
