Old 18th September 2011, 01:40 PM   #1
Default music concrete
hey
i have a mate who works in concrete who like to make some cabinets. i reckon he should go for something thats not easy with wood products like curved cabinets.
Anybody know of suitable designs?
looking at floor standers!!
cheers
Old 18th September 2011, 08:52 PM   #2
some extrra info -
the room in the house he has built is large with a near two story height at one end about 5x7 metres so prob needed 15" bass to fill room!!
Old 18th September 2011, 11:22 PM   #3
Hi, not easy with wood ? How do you expect to make the moulds ? rgds, sreten.
It has been done, it is commercial suicide, as the result has huge shipping costs.
A Metronome is an ideal moulding candidate, but the moulds are just as complicated
as the real speaker, probably more so, given the driver cutouts, makes no sense.
5 pour concrete/cement/plaster lining of basic boxes is a lot simpler and has been done.
Thick front baffle and line the other five faces, the linings don't have to be parallel,
in either plane, so internally the linings could form all sorts of internal shapes.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 18th September 2011, 11:38 PM   #4
juz400 is offline juz400  United Kingdom
I have a Faraday Sound sub, has an 8" driver with concrete cabinet.
It is VERY heavy for its size!
It does have a very solid bass output tho. If you planning something moveable,
I dont think you should go an larger than a 12"
If your not planning on moving it, work out the best sites and build big!
Old 19th September 2011, 12:30 AM   #5
gooki is offline gooki  New Zealand
Go open baffle if you want to accommodate a 15 inch woofer while keeping weight down.
Old 19th September 2011, 12:38 AM   #6
lowpoke is offline lowpoke  Australia
Send a message via Skype™ to lowpoke
You could make it a modular system to make moving them manageable ... i.e. separate enclosure for bass, mids and highs etc. They could stack on top of each other.
Show us what ya got at Homebuilt Hi-fi
Old 19th September 2011, 12:49 AM   #7
Hi, Faraday also made concrete speakers, with Morel drivers, and Audax, I recall, also VERY heavy, rgds, sreten.
The VERY heavy concrete cabinet Morel version was called the Bassmaster I recall.
Old 19th September 2011, 12:55 AM   #8
Loren42 is offline Loren42  United States
Originally Posted by skodaboy View Post
hey
cheers
What does he want for his end goal; great sound, or a sculpture?
To be honest, the acoustic difference between a well designed speaker in a normal wood cabinet versus a concrete enclosure will not likely be very audible. I doubt there will be much cost savings and the difficulty will be pretty high.
What is his budget?
Old 19th September 2011, 03:25 AM   #9
Inductor's Avatar
What is his budget?
"They" also make it of steel, glass, pipes(concrete and plastic), foam, Corian, others... and wood. (and) Bricks and mortar.
Old 19th September 2011, 06:39 AM   #10
seebert is offline seebert  United States
One of the more "interesting" non-wood reflex cabinets I've seen that was quite popular in Europe in the 70's was a complete ceramic toilet. Who was it said form follows function ???
Concrete danerius Full Range 1 11th July 2011 07:15 PM
Concrete Improvement? (Concrete FE168 EZ) Kwast Full Range 9 20th May 2010 09:32 PM
Concrete Subwoofer subwo1 Subwoofers 32 12th August 2009 10:12 PM
Concrete Horns MiWi Multi-Way 52 12th November 2008 05:07 PM
Concrete speaker Dr.EM Multi-Way 17 14th February 2007 01:36 PM
Page generated in 0.15942 seconds (65.57% PHP - 34.43% MySQL) with 10 queries
