Hello,
How would you cross this (already has a 1st order filter at 6 khz) ![]() To this: Seas A26RE4 ![]() This is the speaker: ![]() Any suggestions? Last edited by Defo; 15th September 2011 at 06:13 PM. |
#2 |
Show me a response with both drivers tested together. You may not need any xover.
#3 |
Fooled around a bit with crossover points and found the best overall response with the woofer crossed 2nd order at 500 Hz. Seems I have a floor bounce or something at 500 and 250 hz...
#4 |
Nice to see you again Defo! Long time
#5 | |
The use of the horn might be forgiving for any problems with phase. Distance between horn/drivers is something to consider, so that a lower frequency xover vs on the upper side, might be beneficial. Last edited by Inductor; 16th September 2011 at 12:52 AM. |
#6 | |
The woofer is Seas A26RE4 (pdf in first post) and wideband is Scan-Speak 10F. As of now the bass is OB but the back of the speaker will be enclosed in studio foam in the near future, so it will be kind of a hybrid between OB and aperiodic |
#7 |
A FR, I see, must be delicious.
| Grid Stopper Advice - Graphs Included! | Magz | Tubes / Valves | 43 | 25th July 2010 02:19 PM |
| subwoofers included but not sure where to post.... | lebatt | Subwoofers | 1 | 6th June 2009 01:14 PM |
| Grounding Check please (diagram included) | redrabbit | Solid State | 10 | 15th October 2007 08:52 AM |
| Need advice on crossover design for Vifa XG18 + Seas 27TBFC/G (measurements included) | owdi | Multi-Way | 31 | 19th July 2007 11:47 PM |
| BSOZ Works! (but only 1/3 Done, pics included) | lgreen | Pass Labs | 11 | 17th July 2003 04:26 PM |
| Page generated in 0.08722 seconds (76.08% PHP - 23.92% MySQL) with 11 queries |
