Hello,
I have a dual 4 ohm subwoofer that I'd like to use for home. I have an 8 ohm pair of speakers I'd like to use with it. The tricky part is designing a passive crossover that will accept the two voice-coils in series to present an 8 ohm load to the amp. I need two inputs and two outputs. I could get two massive 4 ohm non-ind resistors to series with each voice-coil but I would like to avoid that. I'm looking for a subwoofer crossover at 80hz. Thanks |
#2 |
I have replied to a couple of these questions. To clarify; you want a single sub 80Hz signal to go to each voice coil?
Cheapest easiest and often the best is to use each VC as a first order XO and use the speakers as a 2.5//3.5 system. Use the inductor with the lowest DCR you can find and if the big drivers have bad break-up it may be beneficial to add a Zobel type network before the break-up. So really all you need are 2 very large coils and cored is fine and I would go a little bigger than simple calculations suggest, 8mH -> 10mH. Most amps will handle the load reasonably well, then experiment with the cable, you may need to reverse the connection to the speakers.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
So, you suggest that I put large coils on each VC and the amplifier would see them as a 4ohm load but since they don't cover much of the audio spectrum my amp won't be bothered much?
#4 |
The load would probably be lower than 4R but a good amp should have little problem in driving a low impedance.
This is the easiest implementation if you do not want to Bi-Amp ( Personally I prefer Bi-Amping for subs but the point 5 is easy and cheap ) The only problem I have is when I crank the volume up; if you want it louder than half your amps output the load may be too much. Can your amp deliver full output into a 4R load?
#5 |
I have a Panasonic SA-HE2000 in Low Impedance mode for the extra current to the main channels. I have driven 4 ohm loads before so I'm not too concerned.
| subwoofer with no crossover | MikeN | Subwoofers | 9 | 2nd December 2008 07:17 PM |
| KEF Subwoofer TDM-45B Crossover Design | misterbobman | Subwoofers | 2 | 12th June 2008 02:59 AM |
| Subwoofer crossover / subwoofer module design | derMichi | Subwoofers | 4 | 20th April 2006 10:31 AM |
| Subwoofer Crossover | Dj BASS AMP | Solid State | 7 | 30th December 2005 04:46 PM |
| Subwoofer Crossover | amoeba86 | Subwoofers | 1 | 17th May 2003 01:53 AM |
| Page generated in 0.08616 seconds (76.25% PHP - 23.75% MySQL) with 10 queries |
