Old 14th September 2011, 12:04 PM   #1
Default "Quad Box" style array?
I have seen these used in PA but not for home use. See attached drawing showing 4 x 6" midwoofers in an old pioneer cabinet below a square tractrix horn. Midwoofers would be wired in series pairs then paralleled to keep nominal 8 ohm impedance I have modelled in edge and it seems to indicate that off axis nulls appear at around 1.5k and up depending on angle. Since I will be crossing at 800hz I imagine this shouldnt be a big problem. What do you guys think?
Pros:
- PA level SPL with decent bass extension and clean mids
- No 12" woofer resonance / breakup to worry about
Cons: Potential phase / lobing issues???
Old 15th September 2011, 01:32 PM   #2
I actually do remember seeing a somewhat similar open baffle array posted here a while ago. Search hasn't turned up anything, if anyone knows the project im referring to and can point me to it that would be great.
Old 15th September 2011, 08:37 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Here is two I kept a record off:
Tired of small scale OB, going big..Selenium 15PW3-SLF-15 questions.?
Sensitive Wide Range OB - Update - Tonemaster
b
Old 15th September 2011, 11:43 PM   #4
Thanks Bjorno,
What is the program you used in the first link to model vertical and horizontal polar response? Based on your experience do you have any comments on the arrangement I posted above using 800-1200 hz crossover point with 6" driver in matrix arrangement? Thanks
Old 16th September 2011, 02:11 AM   #5
Thanks Bjorno,
Hi dabbler,
It's the driver inter C-C distance that for perfect(symmetrical) vertical or horizontal dispersion should stay below lambda/4, that is ~560 Hz but no more than 800 Hz (i.e. blameless => and less than lambda/2) using a >=24 dB LPF/HPF should work just fine too.
Arrayshow:
Beyond the Ariel
b
Old 16th September 2011, 10:31 AM   #6
FYI: A new URL to EV ArraySHOW:
Electro-Voice Downloads
b
Old 17th September 2011, 01:23 PM   #7
Thanks for those links i'll give the EV app a try
"Adagio" style Tube DAC slav Swap Meet 11 19th July 2011 07:28 PM
"Blameless" style ~100W amp with CFP output. mnturner Solid State 40 17th May 2011 01:14 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
Where to buy "Yamaha M-85" style red LED diodes? Spilferderber Solid State 12 20th December 2006 07:56 AM
Simplified LM3886 amp pcb "organic" style Groundloops Chip Amps 0 23rd May 2006 02:46 PM
Page generated in 0.10135 seconds (81.50% PHP - 18.50% MySQL) with 11 queries
