Old 14th September 2011, 04:57 AM   #1
Default Unity/Synergy horn
Is it possible to create a round conical Unity horn? My assumption is that the normal horns have square walls because it's easier to mount the mids. Is this correct?
Old 14th September 2011, 06:16 AM   #2
Pallas is offline Pallas  Pakistan
Yorkville Sound: Unity™
No real knowledge to that point, but my guess is some combination of array ability and easier construction in small quantities (sheet materials rather than a molded part).
Old 14th September 2011, 06:39 AM   #3
Thanks, didn't know Yorkville made conical ones.
Since a conical horn is very close in shape to an OS waveguide, could an OS waveguide be designed with 2, 3, 4... side-entry mids like in a Unity horn? Perhaps a B&C DE5 or DE7 (smaller throat for higher cutoff with larger mouth) with two mids, two midbasses?
Old 14th September 2011, 07:27 AM   #4
I recall Tom and others saying in the past that one advantage of the square horn is that pressures are lower in the corners. This helped reduce the HF's interaction with the midrange driver ports.
Old 20th September 2011, 05:01 AM   #5
paulspencer's Avatar
Jason hit the nail on the head. That is the downside with the Yorkville Unity. From a DIY perspective, an axisymmetric is more difficult to build and even more so if you want a different aspect ratio.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 20th September 2011, 05:36 AM   #6
Patrick Bateman's Avatar
Most of my Unity horns were elliptical oblate spheroidal.
Check out my threads on audiogroupforum, diymobileaudio, and my own forum. (forum.audiopsychosis.com)
They worked fine for me, and I prefer EOS because it has a number of advantages:
#1 - EOS is less prone to the on-axis "hole" that plagues OS waveguides
#2 - EOS has less diffraction than a conical horn
#3 - For reasons that I'm too lazy to document here, Unity and Synergy horns work a lot better when the average coverage angle is narrow. IE, a 90x90 Unity horn won't work as well as a 60x45 Unity horn. My EOS waveguide was 108 degrees by 72 degrees IIRC
Old 20th September 2011, 05:39 AM   #7
I found that out as well with the sims, so built a 60 x 60 first. Now working on a 60 x 90 with 6 drivers and aiming to get down as low as I can, probably about 220 Hz.
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
DIY Synergy horn ideas nl Multi-Way 8 3rd September 2009 03:42 AM
Not Another Unity Horn Patrick Bateman Multi-Way 29 26th July 2009 04:17 AM
Page generated in 0.09519 seconds (76.28% PHP - 23.72% MySQL) with 10 queries
