Old 10th September 2011, 08:45 PM   #1
Default Calculate box air volume.
When I figure the air volume of a box I need to subtract things such as port volume, bracing and the room the driver takes up. Mostly cone drivers.
I had this information for 5", 8", 10", 12", 15" and 18".
I believe I got this from one of the driver manufacturers (Eminence?), but I can not find it.
If anyone has these figures let me know.
NOTE: I understand these figures are not accurate , but they work well enough in practice.
Looking at the back of the driver and adding Kentucky Windage helps.
Thanks.
Old 11th September 2011, 12:30 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Curt?
One way to estimate is use the volume of a cone the diameter of the driver piston and the depth/height of the magnet. V = pi*rb^2*h/3 so if you have a 12" driver with a 6" magnet height the area of a cone ~10" in diameter (5" radius) and 6" tall is 5^2*6*pi/3 or 157 in^3 or 0.09 cubic feet or about 2.6 liters (a liter is 61 cubic inches more or less)
Another thing I have read in the literature is somewhere between 0.4 and 1.0 times the advertised radius cubed, which would be 86 to 216 cubic inches in the example above.
For the most part this is insignificant, but it can add up.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 11th September 2011, 12:46 AM   #3
Thanks.
This calculator will get you closer:
Speaker Driver Displacement Calculator Help
Old 12th September 2011, 03:54 PM   #4
That is quite a piece of work.
I wish I could download the ap so I know I have it for the future.
Old 12th September 2011, 03:55 PM   #5
Thanks Ron
Old 12th September 2011, 10:23 PM   #6
Hi there Too Tall.
Also, don't forget that damping/stuffing materials will actually increase the apparent (calculated) volume of the enclosure. Refer to the bottom of Troels Gravesen's web-page about this:- http://www.troelsgravesen.dk/ports.htm
J
Last edited by tassie tiger; 12th September 2011 at 10:51 PM. Reason: Wrong web-link, sorry!
Old 12th September 2011, 11:31 PM   #7
Ron E's Avatar
Thanks Ron
For giggles, I looked up the old Adire Shiva 12" driver and the specs say 3 liters or 183 in^3. So my method at 2.6 liters is fairly close. I put in shiva dimensions and got ~1.85 liters in the calculator page....
Help calculate enclosure volume Sillyboy Multi-Way 25 5th May 2006 11:22 PM
How to calculate volume, F3 for 2 drivers? ezkcdude Subwoofers 2 26th January 2006 07:41 PM
Calculate box for basreflex weedo Multi-Way 2 29th December 2005 04:31 PM
how do I calculate the sub box enclosure? Tony.ca Multi-Way 5 8th June 2003 12:05 AM
Calculate Volume for Triangular Prism..I think Bose(o) Multi-Way 4 12th June 2002 12:55 AM
Page generated in 0.10410 seconds (77.71% PHP - 22.29% MySQL) with 10 queries
