Hi All
I would like to design a 2.1 subwoofer - satellite system. They would be used as monitor system in my small home studio. Something like: Blue Sky MediaDesk 2.1 MKII | Sweetwater.com. But... where / how do I start? Cheers Erik |
#2 |
Would these suffice?
Xenums: ![]() Xenums_Duoxenums pictures by wolf_teeth_speaker - Photobucket Use this for a sub...a 9" cube. The KG3100 from Madisound will fit, but you'll need to enlarge the enclosure to allow for the amp. Biumph or Triumph, depending on where you get your PR: ![]() Triumph pictures by wolf_teeth_speaker - Photobucket It's what I built and use myself, so it does work. Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#3 |
When the satillites are that small ( as I imagine they don't extend real low ; you cross them @ 100 -120hz??) Are the sats ported or sealed ?
It's quite a good Idea to have R &L (2) subs! . Looks like a real cool set up wolf !!! For the OP ; Yoy may stumble upon many folks who hate using subs for mixing audio . I suspect that those are the folks who haven't dug deep enough and studied how deep ( yup , lame hertz pun ) the subject of sub integration can get ..... Hint your room will make a big difference at those low down frequencies ! |
#4 | |
#5 |
I have no clue what you mean here :-)
Apart from that: great looking build! What is the size of the satellite? And what drivers did you use? And what made you chose those drivers? Cheers Erik edit: Fiva XT 25SC50 Tang Band W3-315E Last edited by erikb1971; 10th September 2011 at 01:58 PM. |
#6 |
#7 |
Grinn! Let's say about 300-400 dollar for the satellites......
#8 |
I have stumbled upon these drivers: H1333-08/06 T18RE/XFCTV2
How do you guys feel about using such a coaxial driver opposed to a traditional 2 way system? |
#9 |
Why subs,
You can make a compact 2way BR monitor that can do 30Hz. Here a 20 liter tuned to 32Hz wil do 30Hz -3dB when place on a table or in a book case then the low-end will rise 3-6dB. even 25Hz will be reproduced with a 20liter enclosure. Lets say 17liter with damping will make 20liter. And a amazing 87dB 1Wmtr. ![]() Tweeter a monacor dt28 or a ringradiator of vifa. DT28. 28mm dome! for low XO 2kHz.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 11th September 2011 at 04:39 PM. |
#10 |
I actually ment this link: H1602-04/06 L12RE/XFC
20 liters for satellites is a bit too big for my goal... iam thinking more towards 2 liters! |
| Help on designing full DHT SET power amplifier | milen007 | Tubes / Valves | 56 | 11th August 2011 09:38 PM |
| Recommendations for an accurate, detailed, monitor design | Phlim | Multi-Way | 7 | 28th September 2006 07:38 AM |
| Help designing a new set-up. | djames03 | Car Audio | 4 | 12th May 2006 03:32 PM |
| Accurate Studio Monitor Project | Felnik | Multi-Way | 15 | 2nd March 2004 01:00 PM |
| Page generated in 0.11068 seconds (81.00% PHP - 19.00% MySQL) with 11 queries |
