Old 7th September 2011, 01:39 PM   #1
lduarte1973's Avatar
Default eminence speakers
are this good for home use ?
Speaker Detail | Eminence Speaker
Old 7th September 2011, 03:39 PM   #2
Loren42 is offline Loren42  United States
Depends on what you want to use it for.
It is designed for a sealed cabinet and to produce mid-bass. So you still need a woofer because the lower end of the Eminence is a little high.
It is not an expensive driver and as such will not likely compete with better and more expensive drivers.
Old 7th September 2011, 03:58 PM   #3
that´s what i thought , i was looking for a woofer 90-92db with 150-200w
Old 7th September 2011, 04:02 PM   #4
What are you trying to make?
What is your budget?
Old 7th September 2011, 04:17 PM   #5
2 sets of home speakers active minidsp , mids 92 db tweeters 93 db (i already have those) , my budget for 4 wooffers is 400$
Old 7th September 2011, 04:45 PM   #6
Can you tell me what drivers you have so far?
[p]
Is there a specific size for the woofer?
[p]
Why 2 woofers per enclosures?
Old 8th September 2011, 12:03 AM   #7
since i have 2 active subs , i wouldn´t need anything bigger than 8"
2 sets of speakers - 4 "towers" 3 way
SPH-102KEP - Monacor high-tech midrange speaker 8 Ohm - Europe Audio
mid is 88db
810921 - Peerless 1″ tweeter - Europe Audio
tweeter 91db
Old 8th September 2011, 09:45 AM   #8
jerome69's Avatar
Go to this woofer ? : 22W/8534G00 - Scan-Speak 8,5 inch woofer fibre glass cone - Europe Audio
The choice is very limited if you don't like paper, the upper mid is keyvlar, and you have a limited budget.
You have sub, why don't you go to a simple 2 ways ? 3 ways is not necessary in your case. If you like new exploration in audio... You can do something as an OB speaker to cover 150-20kHz. Crossover frequency 1500/2000Hz.
The baffle : Dipole protos
Or a MTM : Dipole Main Panel
Note you can always do your 3 ways if not happy.
Old 8th September 2011, 11:23 AM   #9
i like those scanpeak , or the visaton gf200 i have 2 of these already
GF200 - Visaton 20 cm (8 inch) High-End woofer with double voice-coil - Europe Audio
Old 8th September 2011, 11:49 AM   #10
jerome69's Avatar
It's a very good choice ! You can do something
just buy two 2 GF200 more if you want bigger ?
I forgot the question in the thread, yes you can use the eminence for home use as midrange.
FS: pair Eminence Omega Pro 15A woofers & pair Eminence PSD 2002 8 nicksgem10s Swap Meet 0 30th June 2011 12:37 PM
FS- Eminence S2010 Speakers Pyroibw Swap Meet 1 21st April 2011 01:32 PM
FS: 2 Eminence Patriot Lil'Buddy Speakers xecluded Swap Meet 0 3rd January 2010 01:34 AM
Eminence speakers - new saga! akis Full Range 31 24th September 2009 06:39 AM
speakers Eminence foundtek etalon90 Vendor's Bazaar 0 16th December 2006 07:33 PM
Page generated in 0.10043 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
